Fan Spacer advise....
I converted from a long water pump to a short WP, and moved the ALT to the drivers side with the correct brackets. I am using a polished aluminum short water pump and polished aluminum upper and lower pulley's. Problem is my 3"-4" fan spacer that came with the engine...that goes on the front of the upper pulley and then the fan bolts thru to the WP, no longer matches up to the holes. Do I need a special fan spacer for doing what I'm doing here?
Alex 1971 Lil' Red 350 SBC 700R4 Last edited by ChevyDude; 07-07-2005 at 11:53 PM. |
You shouldn't need anything else. My brother has short w/p and I have long w/p and we have switched fans and spacers before with no problems. The only thing you would really need is a longer spacer since your fan will be further from the Rad.
For every person with a spark of genius, There are a hundred with ignition trouble. ![]() |
Well, I guess I need the right fan spacer unit....the one I have will not fit due to the holes not matching up. Who sells these fan spacers??? Ebay???
Alex 1971 Lil' Red 350 SBC 700R4 |
![]() Join Date: Nov 2004
Autozone or advance has them, they are usually near their flex fans they sell. They usually have several different choices. If the spacer holes don't match up, then your fan holes most likely won't line up either, may need to get a new fan/spacer. I thought the short and long pumps had the same hole pattern
Jesse James 1967 C10 SWB Stepside: 350/700R4/3.73 1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc 1968 Pontiac Firebird: Project Fire Chicken! 2015 Silverado Double Cab 5.3L Z71 2001 Jeep Wrangler Sport 4.0L 5spd 2020 Chevrolet Equinox Premium 2.0L Turbo 2011 Mustang V6 ~ Wife's ride ![]() American Born, Country by the Grace of God ![]() 1967 CST Shop Truck Rebuild! My 1967 C-10 Build Thread My Vintage Air A/C Install Project "On a Dime" Trying my hand at Home Renovation! 1965 Mustang Modifications! |
#5 | |
Cantankerous Geezer
Fred There is no such thing as too much cam...just not enough engine. ![]() |
So, he may need a new fan as well then..... Thanks for the info Fred.
I found a nice billet polished aluminum 3 1/2" fan spacer on ebay. If my fan doesn't fit or work with it I'll get a new fan...PERFECT!!!! Thanks Guys!!!
#8 | |
Got bored, sold everthing. Got bored, looking for a 1960-66 C-10. Want to build my last truck. |
