Old 06-21-2002, 10:09 PM   #1
69 1/2 Sixpack Bee
Old Air A/C Mounting Bracket Question For Big Blocks
I got the A/C today that I got through GMC Pauls...Thanx again Paul!! Super guy and a great product from Old Air too. The compressor mounting bracket I have with this kit is their part # 40-100R and it says it is for a small block. I have a 402. For you guys that have done this install, is the same bracket used on small and big blocks?
I am putting this in tomorrow and I am on a roll so I hope this is the right one.
Thanx all!
69 1/2 Sixpack Bee is offline   Reply With Quote
Old 06-21-2002, 10:35 PM   #2
mikej71
Unregistered User
mikej71's Avatar
I'm sorry, I don't have an answer to your question, but I'd like to know about the a/c system. What type of controls did you get?
I've heard of some that use your existing heater controls, and some that have under-dash knobs. Also, did you go with in-dash or under-dash vents? I hope you have the correct bracket, and that the install goes smoothly. Let us know how it goes.
71 SWB Stepside
SB400/TH350
mikej71 is offline   Reply With Quote
Old 06-22-2002, 07:25 AM   #3
GMCPaul
Bud I already sent a email but in case you read here first that bracket should be a 40-104R not a 40-100R, I will be calling Old Air notifying them of the wrong bracket in the kit and you should also for fastest exchange on it. 1-817-531-2665, I believe I originally dealt with Kenny on your system but any of them at old Air can set up the swap on brackets. Sorry to put you through a few more days of heat!!
GMCPaul
GMCPaul is offline   Reply With Quote
