Question about the front Coil Springs!
Hey there!
Question about front suspension. Originally my truck had a line six, but i wanted a V8 so that's what i did. I built one into my truck. But now my front wheels look like this / \ because the V8 is more heavy than the line 6. Does it help when i install heavy duty front coil springs? If it does, are there heavy duty front springs that lower my truck but keep my wheels straid? The reason i ask you this is because i like the front lowerd but i wanna keep the wheels straid. Are there any other options? I tought about spindels, but i live in the Netherlands (europe) and shipping is realy expensieve, so that isn't much of an option i think. Any idea's????? |
67 is sold
The Early Classic front coil springs come in two varitions, for a 6 cyl/Small block setup or for a Big Block setup. maybe your front springs were pretty worn to begin with?
blood type; Retumbo
these trucks have a nasty camber curve. (mine has a neutral one now)
try getting a good alignment. or a straight piece of steel to span the wheel itself. then use a magnetic protractor to do a preliminary set-up at home. this is how I ended up with only being off 1/2* from specs/
Man rule #77...if you own a 67 stepside with a caddy 472 you will never be in danger of loosing you man card |
More Cowbell....
I changed from an inline 6 to a small block V8, and haven't noticed a difference in mine at all. I know that one is tired & weak, cause the front leans a little to the left, but it has been like that for years. Mine doesn't sit any lower either.
There once was a member from Puckett.....Who ( fill in the blank blank blank ) bucket Last edited by Putter; 07-08-2005 at 09:56 AM. |
ditto for me. I swapped my inline 6 out for a 350 over a year ago and haven't noticed anhy difference. If anything it rides better now that there is some more weight up front
My name's Tim and I'm a truckaholic My 56 Chevy shop truck build http://67-72chevytrucks.com/vboard/s...d.php?t=562795 |
![]() Join Date: Nov 2004
I took the coil spring front suspension out of a 71 V-8 GMC 1500 and put it in my 67 C10 that had an I-6 but is now a V8. I did notice that the GMC's springs were a little heavier AND had 1 extra coil. I figured they were 4 years newer and heavier duty, so I put the GMC springs in my truck. Like the others said, it may not be a problem with your springs, but maybe the alingment, or your springs are somehow badly worn
Jesse James 1967 C10 SWB Stepside: 350/700R4/3.73 1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc 1968 Pontiac Firebird: Project Fire Chicken! 2015 Silverado Double Cab 5.3L Z71 2001 Jeep Wrangler Sport 4.0L 5spd 2020 Chevrolet Equinox Premium 2.0L Turbo 2011 Mustang V6 ~ Wife's ride ![]() American Born, Country by the Grace of God ![]() 1967 CST Shop Truck Rebuild! My 1967 C-10 Build Thread My Vintage Air A/C Install Project "On a Dime" Trying my hand at Home Renovation! 1965 Mustang Modifications! |
its all about the +6 inches
Look where the upper control arm bolts to the frame. you'll see shims in there. You need to add shims untill the wheels are like this l----l You may well have weak coils, but you can cruise with weak coils no problem. My old GMC had sagged about 3 inches in front due to 500,000 miles and it rode fine, only bottomed out a few times, and it was onto the bumpers, never the headers or oil pan.
(suspention bumpers)
~Rest In Peace~
no difference here either and im adding on 200 lb with the blower
is it fast ? it has a lighting bolt donut? B___H please, I can remove 90% of your so called "beauty" with a kleenex |
![]() Join Date: Apr 2000
i thougth there were only two different sets of factory springs for these trucks 1/2 ton with 6cyl. - sb 8 or the 3/4 ton sb /big block set??
the 3/4 ton springs were used in the 1/2 ton that came with the big block.. hope this makes sense.. ![]()
jamie72 72 BB cheyenne -- Restoration getting started.. member #807 http://www.myspace.com/whitetailobsession www.antlertalk.com |
jamie...I always thought that too, but some one once told me there were actually like 17 different part numbers for front coils on the 67 - 72 trucks.
No proof though. |
Excelsior, You Fathead.
Mine had a 6 and now an 8. Looks the same.
Go Navy. The Sea Is Ours. Budget 350 Build http://67-72chevytrucks.com/vboard/s...38#post2264638 |
#13 |
![]() Join Date: Jul 2004
Correct me if I'm wrong but if the wheels are sitting like /---\ then it is sitting HIGHER than it was, thats what they do when the engine is out right ? I replaced the 6 banger in my 70 with a 283 in correct V8 front position and was hoping that it would bring the front down a tad, as it sits higher in front than my stock sprung 68 with 307, but I could not see a difference.
1968 C10 307 3spd Long Fleet ------ http://67-72chevytrucks.com/vboard/s...d.php?t=201103 1970 C10 305 Super T10 Long Fleet --- http://67-72chevytrucks.com/vboard/s...d.php?t=202285 1971 C20 383 TH350 Dana Posi ----- http://67-72chevytrucks.com/vboard/s...d.php?t=206894 2001 GMC Sierra 1500 C3 6.0 |
#14 |
green, you have it backwards man
#15 |
Check this pic out. The top A arms are much shorter than the bottom. As the front end rises, the top a arms get shorter quicker than the bottom A arms, hence the top of the wheel will pull in and wheels will sit like this /----\.
#16 |
green that actually makes sense...
#17 |
![]() I tought i wouldn't matter also! I'va taken everything apart, cleaned and painted all the parts and after that i installed everything by the book. Mayby i did something wrong? ![]() Do you have any pics off your front suspention?? |
#18 |
not much help here but fyi. i went from sb to bb and see no change
