Old 07-08-2005, 03:00 PM   #1
pbmcauliffe
pbmcauliffe's Avatar
315/60R15 fitting on 67 -search down
I guess I din't realise the search is gone, and a google search for this site didn't help me, so here goes.
Currently running 275/60 on the rear and bagged, so the 15x10 w/4" bs didn't fit so I went with a 15x8 w/4" bs and that worked (barely, close to the outside fenderwell).
Now I would like to go to a 315/60/15 or 30/31x13.5's and curious if anyone has ran this size w/o narrowing the rearend or having them stick out the fenderwell, if so what rim size and b.s did you have? I already have another set of wheel tubs to extend mine and there is room to the frame, so that is no problem, the rearend is a 4.11 posi that has been gone thru so I would like to get away w/o changing it.
Maybe a 15x10 with 6" bs?
pbmcauliffe is offline   Reply With Quote
Old 07-08-2005, 03:08 PM   #2
camaro__thunder
Epoxy Primer Friendly
camaro__thunder's Avatar
fit
when BAGGED I know a 15x10 with 5" backspace wont work with a 295/50
My Project 69 SWB
SHAVED BAGGED DOORED
camaro__thunder is offline   Reply With Quote
Old 07-08-2005, 06:48 PM   #3
SCOTI
SCOTI's Avatar
If your 15x8 w/4" bs worked, then I would say yes on the 15x10 w/6" bs in conjunction w/a mini-tub job.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
