07-08-2005, 04:22 PM | #1 |
Excelsior, You Fathead.
HEI and Electric Choke conversion wiring
I would like to run a wire through the firewall for my HEI and Electric choke. I would like to use the two IGN UNFUSED connections on my fusepanel for those. Is there a grommet that I can put on the firewall and run the wires to the engine bay? I don't want to mess with the original wiring harness. Any other ideas are welcome.
Go Navy. The Sea Is Ours. Budget 350 Build http://67-72chevytrucks.com/vboard/s...38#post2264638 |
07-08-2005, 04:37 PM | #2 |
More Cowbell....
If you don't want to mess with the original harness, then just drill a hole in that sucker and stick a grommet in there from Autozone.
But to modify the original harness is only one wire.
There once was a member from Puckett.....Who ( fill in the blank blank blank ) bucket Last edited by Putter; 07-08-2005 at 04:37 PM. |
