Best Headers for Bagged Truck
Its been a while, but I am starting to work on ol84 again. Needing a little help. I just purchased some Hooker Super Comp headers for my 84. They are awesome but they hang down too low. I will be bagging my truck in the next couple of months. If I use the Hooker Super Comps that I have I will not be able to lay frame so I am sending them back to summit. Do any of you have any suggestion on the best header for what I want. I currently have some long tube headers that stop at the frame rail on it but they have small diameter tubes. I am searching for the largest diameter tubed header I can find. I would like to stick with long tub headers but I will consider shorties. The super comps had 2" primaries, they sure would have helped the ol84 breath better. Let me hear from you guys. Almost forgot, I have a BB402 matched to a th350.
Thanks, Rusty
1984 C10 SWB Custom Frame Blow Through Carb Single Turbo Hope to be on the road by Summer 2018 1967 C10 CST LWB 327/PG Original Running Driving Future Project |
It followed me home?
I am running sanderson headers and will be bagging the front of my truck soon. A little expensive but they havent discolored or leaked in 3 yrs.
Adam That's why they call it a shortcut Kyle, if it was easy it would just be the way. 86 c-10 SWB 85 CCSB 90 GMC K30 Crew SRW 1985 C30 Dually Last edited by cochino12; 07-08-2005 at 09:51 PM. |
Hotwheels?
Well, you could use some chevelle 3/4 lengths like a couple members use around here, they will tuck with the right exhaust setup.
I use Thorley longtubes and they tuck just fine. I do scrape the crap out of em on big bumps when driving low though, airing up helps that though ![]()
1978 Money Pit - CUSTOM DELUXE!!!! |
r0lf, do you know what year Chevelle they are for?
Cochino, thanks great looking truck!
#5 | |
Got bored, sold everthing. Got bored, looking for a 1960-66 C-10. Want to build my last truck. |
Heddman Hussler headers for a 67-69 Camaro. only 1 7/8" primaries, but tuck nicely into the frame. the only downside, is some minor massaging to get them to fit, along with fabrication of a trans crossmember to clear the dual exhaust.
scratch that, i didnt notice you have a BBC.
hooker #2455
86 SWB 9.0 LITER T-400-OD 4.11 eaton-4/5 drop Best 1/4 12.51 @112mph no traction ![]() |
im goin to be runnin wither ram horn or short length headers i got one but i had a pair until my dad used them on his coupe
http://img.photobucket.com/albums/v5...ropped/sig.jpg |
Thanks for the input, going to check on those hooker #2455
Airmale, are you running the hooker #2455 on your BB? If so, would you happen to have a pic of where the collectors sit after install? I new I should have done this before I ordered mine...the #2455 are almost $200 cheaper than the ones I got
hope this helps
#13 |
Got big-block?
![]() Join Date: Jul 2000
I'm running Hedman #68610, Chevelle big block shorty headers on my '81 454/T350 combo. They're $135 from Summit...that's for black painted...ceramics are more of course. Fit fine except I had one tube on driver's side I had to massage a 1/4" where it sat on the motor mount...other than that no probs. I just dropped the truck 4/5 and have no clearance issues whatsoever.
Here's a couple of pics:
'68 CST SWB factory 396/T400 buddy buckets, a/c, ps, pb '72 Corvette convertible 454/4spd/ac, ps, pb '73 GMC Sierra Grande short wide 454/T400 ps, pb, ac '77 K5 Blazer black on red, 350/T350/NP205 ps, pb, ac all original '78 GMC Sierra Classic short wide 454/T400 ps, pb, ac '72 GMC Sprint SP454. 1 of 38 built. '73 GMC Sprint SP454. 1 of 71 built. '75 GMC Sprint SP454. 1 of 25 built. SOLD! '72 GMC K25 4x4 468/4L80e/NP205 build thread http://67-72chevytrucks.com/vboard/s...23#post4324423 SOLD!'55 Chevy gasser 496/4spd build thread http://67-72chevytrucks.com/vboard/s...96#post4324396 |
#14 |
Thanks guys, I am going to go with the Hooker #2455. When I get the truck all done, I will post some pics. Going to be getting a 9inch, 4 link, bags, air control arms backhalved, aerospace engineering disc brakes on all corners done in the next couple of months. I already have the bag setup and airarms. Should drop it off at the shop by begin of september for all of the rear suspension stuff. I will be doing the bag setup. Anyone have some pics of how/where they have their compressor and valves mounted? Just tossing around ideas in my head seeing what others have done.
#15 |
i seen ppl mount them right were the spare tire went , were the gas tank was on either side of the frame i even seen them mount the valves in the cab and make them real quiet
