Old 07-09-2005, 01:44 AM   #1
tomatocity
tomatocity's Avatar
Blazer gas tank install tech article
http://www.brotherstrucks.com/tech/t...NSTALLATION%20
This is the Blazer/Suburban gas tank install Tech Article from Brothers. It does mention some trucks need to trim the bed sill but it does not sasy which models require the trimming. Does anyone know whick models require the bed sill (brace) to be trimmed?
Got bored, sold everthing. Got bored, looking for a 1960-66 C-10. Want to build my last truck.
tomatocity is offline   Reply With Quote
Old 07-09-2005, 05:23 AM   #2
krue
Designated A-hole!
krue's Avatar
http://67-72chevytrucks.com/vboard/s...d.php3?t=74876
May have some info that will help.
Being stupid ain't illegal.
www.daveramsey.com
93 S-10 "Poppaw's Truck"
Old 07-09-2005, 10:16 AM   #3
chevyboy55
chevyboy55's Avatar
I know first hand that a 72 lwb does.
chevyboy55 is offline   Reply With Quote
Old 07-09-2005, 02:44 PM   #4
superfly68
superfly68's Avatar
i know i had to section mine on a 68 steel bed. pretty sure it's the same for all models.
no longer have a ride, but still a fan!
superfly68 is offline   Reply With Quote
Old 07-09-2005, 02:50 PM   #5
superfly68
superfly68's Avatar
pics always help...
Old 07-10-2005, 05:50 PM   #6
jcfoote60
Active Member
jcfoote60's Avatar
What did you use to cut the bed support? Looks like a torch (which I don't have, or a plasma cutter). Do you think it could be done with an air cutoff wheel? I would guess I am SOL unless I invest in the proper tool or find someone to help out!
jcfoote60 is offline   Reply With Quote
Old 07-10-2005, 05:59 PM   #7
longnlow72
longnlow72's Avatar
yes it can be done with a cut off wheel just stock up on wheels thats how i did mine
72 Chevy lwb, cowl hood, shaved antenna, shaved bedrails, blazer tank, sidemarker fill, 1pc windows, flowmaster 40's, alpine deck, infinity 6x9's, infinity 4"ers, 2 jl audio 10w0's, grant wheel, keyless entry and alarm, more waiting to be done...
longnlow72 is offline   Reply With Quote
Old 07-10-2005, 07:36 PM   #8
Rokcrln
Rokcrln's Avatar
I used a 4" cut off wheel to do the entire body drop on my 71. It is alot cleaner then a torch or plasma (both of which I have). What I like are cut off wheel blades that are not thicker than .040 they seam to last longer than thicker ones and do not drag down the tool as bad.
Kevin
Rokcrln is offline   Reply With Quote
Old 07-10-2005, 07:55 PM   #9
matthufham
Kevin
do you have a pneumatic cutoff wheel? Man that would take forever here waiting for the air to catch up (i have a 13 gallon compressor) but hey, I bet it was worth it.
matthufham is offline   Reply With Quote
Old 07-10-2005, 09:30 PM   #10
Russell
Professional Grade
Russell's Avatar
I just used my actylene torch. Far from pretty, but the tank covers it up real nice like
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap)
Russell is offline   Reply With Quote
Old 07-10-2005, 11:37 PM   #11
crews
It just doesn't matter
I did mine with a cutoff wheel in a right angle die grinder. It took a little longer than a plasma cutter, and isn't as clean initially but I have a lot of sheet metal tools and grinding bits so I cleaned mine up after I was done. It looks good enough for me...
05 Chevy Silverado..... A rogue BMW guy....
If you don't like me- TAKE A NUMBER; There are people ahead of you!!
crews is offline   Reply With Quote
Old 07-11-2005, 01:08 AM   #12
Deuce
Deuce's Avatar
I couldn't bring myself to cut up a mint cross sill so I built 2 stubby sills that mount from the frame outwards.
I know what your thinking.......I have ESPN.
Sometimes it's easier to do things the hard way.
Fesler Built 1968 Chevy C10....Must resist the urge to mess with it!!
Deuce is offline   Reply With Quote
Old 07-11-2005, 09:26 AM   #13
jcfoote60
Active Member
jcfoote60's Avatar
OK, well I have the 4" pnuematic cutoff tool, so will use it. I noticed each picture is with the bed removed from the truck....I counted 8 bolts holding my SWB bed down (unless I missed something). It would be cool to remove the bed to get my gas tank in and would make the cutting a heck of a lot eaiser for the sill modification. My question is, what is the easiest way to lift off the bed? It is just my wife and I so hefting it without help is not an option. Anyone have advice or lessons learned they would like share on getting my bed removed? Thanks for you help!!
Old 07-11-2005, 11:15 AM   #14
crews
Without a doubt this installation is MUCH easier with the bed removed. I am not even sure I would even think of attempting it with the bed in place. I had only my wife avail. when I took it off, but used an engine hoist/ cherry picker for the re-install.
Most tool rental places rent these and they aren't that expensive. I would not try this without some sort of hoist.
Old 07-11-2005, 11:23 AM   #15
superfly68
superfly68's Avatar
ok, here is what i did with mine by myself. Maybe not the smartest way but it worked. I used four ratchet straps(2 per end) and hung them from my rafters in the garage. Hooked them up to each corner and started racheting away. first one corner and then the other to make it even. then on to the other side. until it was high enough for me to roll the truck out from under it. Just to clarify i had 2 straps per end in case one failed. ratchet one up then the other. then move to the other end.
here are some pics....
Old 07-11-2005, 12:07 PM   #16
redhead69
fugedaboutit
redhead69's Avatar
I did mine with jig saw... just took off the gaurd and used a metal blade. Held it flush with the bottom of the bed and used the tool itself as a guide. I did use a cutoff wheel to get a hole started and to cut the vertical cuts. Couldnt have turned out any better IMO.
Currently truckless
redhead69 is offline   Reply With Quote
Old 07-11-2005, 02:36 PM   #17
jcfoote60
Active Member
jcfoote60's Avatar
Hey redhead69 did you remove your bed to do the jigsaw cut or did you just tough it out from below with the bed installed?
Crews, how did you fasten the cherry picker to your bed to get an even lift? It looks like you have it fastened in the middle of your bed somehow but did you fasten on the corners too?? Can't tell from the pics....
Old 07-11-2005, 03:52 PM   #18
Iceman7642
P!$$ on Ford
Iceman7642's Avatar
fillers or bazer tanks
How did u guys get your fillers to work??
mine sucked for a while until i made one out of copper, i think it was a darn good idea and it works like a charm now. But i dont recomened the welding of it while it is part way in the gas tank that has fuel in it...
[FONT="Impact"][COLOR="Navy"]Michael
Lowered 1972 C-20 Longbed with 350 and TH350
1995 Tahoe LS - Custom intake, k&n, TBI spacer, sweet tail lights, clear front lights...
2009 Nissan Versa
I am 26, married, and we had our first baby in July of 2009
Iceman7642 is offline   Reply With Quote
Old 07-11-2005, 04:49 PM   #19
matthufham
at first i had a 77 bed side that i was going to put in the corner of my bed, but i had clearance issues with the side marker light. i was going to just shave the side marker, but shaving X4 is much harder than making a simple box with a hole.
so i scrapped the 77 bedside idea after it was almost complete and just made the box
still not done, ran out of bondo. i plan to cover the bed and box in bedliner
Old 07-11-2005, 04:50 PM   #20
redhead69
fugedaboutit
redhead69's Avatar
jcfoote90..
I just did it with the bed on.. gloves, glasses, and wd40.
Currently truckless
Old 07-11-2005, 04:58 PM   #21
redhead69
fugedaboutit
redhead69's Avatar
Iceman7642- I like that.. looks good!
I did mine just like that but used and s10 filler neck with a reducer on the end, but looks almost identical.. just a bit bigger. Just when I thought I had a one of a kind..haha. I know first hand the head scratching that went on to figure that one out!
Currently truckless
Old 07-11-2005, 06:49 PM   #22
Iceman7642
P!$$ on Ford
Iceman7642's Avatar
i know, i had this image in my head and my dad and uncle didn't understand what i was doing, until i was all done. they were impressed, and i was happy.
2009 Nissan Versa
Old 07-11-2005, 07:12 PM   #23
tomatocity
tomatocity's Avatar
[QUOTE=Iceman7642]How did u guys get your fillers to work??
Very nice. Where is your vent? What is the name of the larger copper piece near the top? What size tubing did you use? I still am not 100% sure of where I plan on installing the filler. Your is very nice.
Old 07-11-2005, 09:12 PM   #24
hilljob26
hilljob26's Avatar
i used a sawzaw on mine,i dont have pics right now,but i made my filler come out the marker light,but i also used a blazer tank out of a 80 blazer,it seems to be alright,i had to modify the inside of the bed,but when all is said and done,u probably wont even see it
21 2500hd duramax
58 apache
HILLJOB GRAPHIX--for all your graphic needs
My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=542497
LS ENGINE SWAP INFORMATION THREAD
http://67-72chevytrucks.com/vboard/s...d.php?t=377348
4l60 to an NP205
http://67-72chevytrucks.com/vboard/s...43#post3697343
hilljob26 is offline   Reply With Quote
Old 07-12-2005, 02:22 AM   #25
tomatocity
tomatocity's Avatar
pics are red x'd
still not done, ran out of bondo. i plan to cover the bed and box in bedliner[/QUOTE]
