07-09-2005, 01:52 AM | #1 |
Transmission fluid leak
Transmission fluid is leaking from the speedometer gear. I don't have the manuals to look it up so does the speedo gear have a O-ring or gasket that could be leaking? Thanks in advance.
Ps-Iwill be getting a Service Manual soon.
Got bored, sold everthing. Got bored, looking for a 1960-66 C-10. Want to build my last truck. |
07-09-2005, 07:33 AM | #2 |
There is an o-ring around the "bullet" that the gear goes in and a metal clad or rubber seal, depending on the type of bullet, inside.
SEMA Network- Protect our Hobby! 71 C30 in pieces, starting to come together. Click here for A Place For Tennessee Truck Enthusiest To Meet |
07-09-2005, 08:30 PM | #3 |
The speedometer gear can also get a groove worn in it from rubbing on the internal seal, so just replacing the seal may not fix the leak.
07-09-2005, 10:56 PM | #4 |
Cantankerous Geezer
If there is fluid in the speedo cable, it's the inner seal. If the cable is dry, it's the outer o-ring. To remove the bullet, jack the rear of the truck up so the fluid flows to the front, and less comes out when you remove the bullet.
Fred There is no such thing as too much cam...just not enough engine. |
07-10-2005, 02:18 AM | #5 | |
Oh yes there is, my truck is ugly but it only has one way to go.
