Old 07-09-2005, 01:59 AM   #1
skokie
skokie's Avatar
What pound size radiator cap
What pound size radiator cap should I go with on a stock 350 with a brand new 3 core radiator?
Thanks ...
RIP to my son Dylan. 5/17/2002 - 8/18/2018
If you want to know more about rare forms of pediatric cancer or if you want to help fund pediatric cancer research, please check out the website for the non-profit I started.
https://slothforpedcancer.org
68 build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=223234
skokie is offline   Reply With Quote
Old 07-09-2005, 02:25 AM   #2
Cheesewagon
Cheesewagon's Avatar
You could go with a 15lb like what came stock with the truck. But if you still have a older heater core I'd go with something between 10 to 7 1/2 lb unit. Just to be on the safe side.
Latter Tom.
'91 suburban 350 TBI - R 700 4 new daily driver
'72 Cheyenne Super 49,000miles 350/350 frame up resto w/ matching numbers.
Cheesewagon is offline   Reply With Quote
Old 07-09-2005, 11:15 AM   #3
fastwillie 696969
~Rest In Peace~
fastwillie 696969's Avatar
16 lb cap
is it fast ? it has a lighting bolt donut?
B___H please, I can remove 90% of your so called "beauty" with a kleenex
fastwillie 696969 is offline   Reply With Quote
Old 07-09-2005, 11:43 AM   #4
StingRay
StingRay's Avatar
You really don't need anything more than an 11 lb cap. If you do the math on boiling points at pressures you will find that you are overheating the engine before you are boiling the coolant over with an 11 lb cap. Most will probably get away with the 7 lb cap. Less pressure means less stress on your cooling system.
Saskatoon, Saskatchewan
Canada
StingRay is offline   Reply With Quote
Old 07-10-2005, 01:46 AM   #5
skokie
skokie's Avatar
The parts store was out of 11 lbs caps but they had a 13 lbs stant one so I grabbed that one. I put it on tonight. Didnt really notice a difference but I did notice that my antifreeze is a dark green. Must be time to change it.
68 build thread
Old 07-10-2005, 09:15 AM   #6
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
I run an 8 pound cap and all is well..
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
Old 07-10-2005, 09:52 AM   #7
Randy70C-10
Randy70C-10's Avatar
I've always ran 13lb caps, no problems ever (been driving 26 years) (yeah, I'm old)
Randy70C-10 is offline   Reply With Quote
