Old 07-09-2005, 06:29 AM   #1
79Silv4x4
Workaholic
79Silv4x4's Avatar
Blower motor does not work on high?
Is it the switch or is there a relay or something else that is likely the culprit?
79Silv4x4 is offline   Reply With Quote
Old 07-09-2005, 09:57 AM   #2
NeCrOmAnCeR
NeCrOmAnCeR's Avatar
Check the blower motor relay. Out in the engine compartment near the blower motor. There should also be a fuse between the power block and the relay which could also be bad.
NeCrOmAnCeR is offline   Reply With Quote
Old 07-09-2005, 10:42 AM   #3
79Silv4x4
Workaholic
79Silv4x4's Avatar
Thanks, I'll look for the relay. . .
Old 07-10-2005, 09:25 AM   #4
gchemist
BAD BOW-Silverado XST
gchemist's Avatar
Relay, I had the same problem. About $6.00 at the parts store.
gchemist is offline   Reply With Quote
Old 07-11-2005, 01:08 PM   #5
BALDMIKE
Enormous Member
BALDMIKE's Avatar
I replaced my relay but now when I switch the A/C to "HIGH" it blows the 20amp fuse in the fuse box ?
Anyone have any Ideas what the hell is going on ?
"79" Chevy Stepside 350/350
Check my Blog @ www.BaldMikesWorld.blogspot.com
BALDMIKE is offline   Reply With Quote
