Old 07-09-2005, 01:29 PM   #1
hAetWagon
Schlongbed MEMBER (heh)#15
hAetWagon's Avatar
Steering box.
I have isolated my steering play to my steering box (which was supposed to have bee replaced I guess)..
it has a good 1/6th of a turn of free play and it makes driving irritating.
(The 2ft steering wheel diameter does not help)..
My questions is :Is that much free play normal? Am I being too nitpicky?
hAetWagon is offline   Reply With Quote
Old 07-09-2005, 05:13 PM   #2
Prerunner1982
Prerunner1982's Avatar
you might check the frame where the box is mounted... might be broken or getting ready to break. more commone on 4wds not than on 2wd trucks, but it does happen.. mine did.. right now i have quite a bit of play in mine but i believe its due to worn tie rods, ball joints, and control arms bushings...
Jon
1982 Chevy Silverado 350/th350.... RETIRED
1993 Jeep XJ 2 door(Cherokee) 4wd 4.0ltr/AX-15 (5spd)/NP231
Oklahoma Roll Call
Prerunner1982 is offline   Reply With Quote
Old 07-09-2005, 05:35 PM   #3
hAetWagon
hAetWagon's Avatar
I'd suspect that if I hadn't witnessed the play while looking directly at the box. The play is internal.
Old 07-09-2005, 05:38 PM   #4
Bob Gervais
Truckless for the moment...
Bob Gervais's Avatar
That much freeplay is not normal. Check the frame, as mentioned by Prerunner. You'll need to remove the steering box to be able to get a good look at it.
Also, I assume you checked all the front end components, did you check the wheel bearings as well? I chased a problem like this on my 87 for a couple weeks, only to find that my Dad improperly set the front wheel bearings and they were way too loose. I set them properly, and it's been fine ever since.
1987 V1500 GMC Suburban, 350 TBI, Flowtech dual exhaust, Rough Country 2" spring lift, 56" 3/4 ton rear spring conversion, 33" BFG All Terrains, and the smokescreen engine mod -- Former truck, searching for another now...
Bob Gervais is offline   Reply With Quote
Old 07-09-2005, 09:28 PM   #5
hAetWagon
hAetWagon's Avatar
Old 07-09-2005, 11:00 PM   #6
chevy71super
Have someone turn the steering wheel back and forth while you watch the steering box, linkage, etc. The source of the slop will become apparent. Don't overlook the rag joint.
chevy71super is offline   Reply With Quote
Old 07-10-2005, 06:44 PM   #7
hAetWagon
hAetWagon's Avatar
ROFL...you guys are just messing with me now right???
I KNOW exactly where the slop is coming from...it is the steering box..
My original question was asked to see if that much play was normal.
Old 07-10-2005, 08:02 PM   #8
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
Not normal, but since your going 6", now is a good time to get a 2wd box and go with crossover steering. You"ll need:
2wd box
dropped pitman arm for box.
pass side flat top knuckle drilled for a new steering arm
draglink to connect steering arm and new pitman arm.
Several companies offer the parts.
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs
1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX
1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears
1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now.....
1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone.
1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed.
1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm
JIMs70GMC is offline   Reply With Quote
Old 07-11-2005, 02:46 AM   #9
hAetWagon
hAetWagon's Avatar
Thanks Jim. I was going to ask about crossover steering ....
