Old 07-09-2005, 04:13 PM   #1
woody96
woody96's Avatar
Loose emergency brake lever/pad--84 C10-HELP!
I have noticed that my emergency brake lever/pad seems to have gotten loose/shaky lately....anyway to tighten this lever or assembly up? Ideas? It rattles, and if I hold the lever/pad while I am driving it of course stops rattling---I looked under the dash at it and it does appear to feel a bit loose---the whole assembly that is.......how and where can I tighten this up?? THX!....BTW, it is an '84 C10 silverado is that matters......
"Fighting for our freedoms....."
woody96 is offline   Reply With Quote
Old 07-09-2005, 06:00 PM   #2
SSC's76
No No
SSC's76's Avatar
Theres a pin that holds the assembly togather over time it wears out. If the pin wears the two peices there isnt much you can do except find a doner ebrake. Now on the other hand if the spring assebly could be broken also resulting in replacment. Now it its just the lever peice moving there is a 2in spring that goes from the lever to the assembly thats gotten broken or gone missing.
1976 Custom Deluxe SWB Med FMB.3/4 Drop.
Gen VI 454, Muncie HD 3 speed With Modified OE Hurst Shifter, 3.73 12 bolt, GMPP HO roller cam, Hooker headers, Performer intake with modified Q-jet, Accel distributor. Best 1/4 12.3 @108. Funnest run 19.84 @88 full 1/4 mile burn out.
1997 K1500 ext cab 5.7 stock except muffler
SSC's76 is offline   Reply With Quote
Old 07-09-2005, 07:10 PM   #3
woody96
woody96's Avatar
Exclamation
THX, it just feels like it is about to come loose for the kick panel...(that make sense??...) Is it attached to the kick panel??
