Old 07-09-2005, 04:27 PM   #1
rpm9100
auxillary heater
is there some sort of secondary heater I can get for the inside of the cab?
Aaron
rpm9100 is offline   Reply With Quote
Old 07-09-2005, 05:30 PM   #2
cdowns
cdowns's Avatar
try replacing the 3o year old heater core and clean the heater housung and with a 195 thermo you'll have more than enough heat
Old 07-09-2005, 06:29 PM   #3
XXL
Seņor Member
XXL's Avatar
Yes. But the electric ones are teh sux0r. You'll get more heat from the high-amp current draw melting wires than from the heat coil inside them
XXL is offline   Reply With Quote
Old 07-09-2005, 07:11 PM   #4
Green Machine
Green Machine's Avatar
I agree with cdowns, a properly operating heater, assuming not to many holes in floor and some normal insulation, that heater would heat a small house LOL.
1968 C10 307 3spd Long Fleet ------ http://67-72chevytrucks.com/vboard/s...d.php?t=201103
1970 C10 305 Super T10 Long Fleet --- http://67-72chevytrucks.com/vboard/s...d.php?t=202285
1971 C20 383 TH350 Dana Posi ----- http://67-72chevytrucks.com/vboard/s...d.php?t=206894
2001 GMC Sierra 1500 C3 6.0
Green Machine is offline   Reply With Quote
Old 07-09-2005, 11:48 PM   #5
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
If you are not getting heat you should check to make sure you have low med and high on the heat fan..
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
Old 07-10-2005, 07:19 AM   #6
dwaite72lnghrn
RPM9100 what year and engine do you have? air or not?
Like stated above normal heat will drive you out of the cab on full and 30* weather outside.
72 longhorn c30 502BB/th400/fact air/4.11rear/ custom camper
72 bug(the better half's) under reconstruction
2009 HHR aqua blue
71 GMC k20 350/sm465
2009 Chevy hd3500 6.6 Victory Red crew cab dually
Dave & Jeanne
dwaite72lnghrn is offline   Reply With Quote
Old 07-10-2005, 03:10 PM   #7
rpm9100
It is a '70 with a big block and no air, I am just a little worried for the winter. it gets mighty cold here, -60 celcius sometimes.
Aaron
Old 07-10-2005, 05:36 PM   #8
dwaite72lnghrn
A 195* thermostat should keep you warm. If it is factory setup the return might be going into the radiator which will increase the engine warmup time but should give good heat once it is up to temp. A peice of cardboard over half of the rad when it is really cold would help. I am sure our other northern friends will help. The alaska crowd or BC, alberta, manitoba,saskatch, maine. They all get that cold.
Your biggest problem will be getting it started in that temp if you don't have a block heater.
2009 HHR aqua blue
Dave & Jeanne
Old 07-11-2005, 06:18 AM   #9
4x4Poet
Insulate the floor and make sure the door rubber seals well. Cold temps tranferred thru metal and cold air entering the cab from other than the heater system are the only things that can hamper a properly functioning heater system. Also, check the heater valve. It may be corroded. Does the heat lever operate smoothly with little resistence?
'71 GMC K20 Suburban, '71 GMC K10 Suburban, '72 Chevy C10 CST Suburban, '72 Chevy K20 clunker pickup.
4x4Poet is offline   Reply With Quote
