Rear bumper brackets different from pickups?
I am replacing my late model bumper with a sport bumper. The brackets I have are hitting the body mount. I pulled a bracket off my 4x4 Blazer and it has been clearanced so it doesn't hit the body mount. I assume this is the way Blazer brackets were correct? So I can just remove some material from my truck bumper brackets to make them fit?
I have attached a picture. The one off the Blazer is longer, but it looks like I will still have at least two bolt holes that match up with the frame on the shorter one. I don't want to remove as much material b/c you can see that the one broke at a bolt hole.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs. |
SKINNY TIRES RULE!
2wd & 4wd bumper brackets are different. I'm not sure what is different, perhaps what you posted. I just know there are always separate listings for 4wd brackets.
bouncytruck 1972 K5 The Hauler 1994 K1500 Suburban The Daily2010 Kia Soul Wife's Ride2014 Fiat 500L Last edited by bouncytruck; 07-09-2005 at 11:53 PM. |
I thought that was the front brackets. The front brackets are different because of the spring hangers.
SKINNY TIRES RULE!
Ahh, could be. I just remembered there was some that were different.
bouncytruck 1972 K5 The Hauler 1994 K1500 Suburban The Daily2010 Kia Soul Wife's Ride2014 Fiat 500L |
Is there a coil vs leaf difference in the rear?
The LuvShack Garage
Here is a pic of the ones I sold to a member earlier this year,
I did not need them because a 72 Blazer uses the end of the frame as the inner brackets, and yes 2wd and 4wd front are different also because of the spring hangers as mentioned ![]() *Can't verify whether or not they are p/u or blazer, my PO got alot of parts for "GQ" off of a rust free cali 67 cst p/u ![]()
Owner/Op: "TN Classic Transport Carriers" The Toy: "Square Vette" 72 Hybrid Blazer Toy Barn: "LuvShack" 40 x 60 x 20 Shop Big Piggy: "Goliath" 07 Kodiak C4500 Lil Piggy:"Maddy" 88 Silverado 3500 Hauler: "Feathers" 14 Aluma 8218T |
Project Junkie! Fishing Poor!!
![]() Join Date: Dec 1999
This set of bumper brackets is for the SWB 2X4 and all 4X4. Note the length and reinforcement piece welded to the bracket.
![]() Here is the LWB 2X4 and Coil Spring Rear set. Note they are shorter and no reinforcement. The outers are the same. ![]() I would guess that the reinforcement would keep the bracket from braking like 71swb4x4's. WES www.ClassicHeartbeat.com
On-line catolog Classic Heartbeat Pickup Parts WEHEPP@comcast.net Call us Toll Free (888) 338-2502 Like Us on Facebook No appointment necessary. 72 BB Chevy Custom Deluxe / Custom Camper 67 I-6 (Soon to be 5.7 LS1) Panel 68 BB Chevy Short Bed 72 6.0 LQ9 Short Bed Chevy 4X4 Olympia's fastest growing truck parts supplier. Olympia's home for Wayward Chevys |
Thanks for the pictures Wes. So should my 2wd Jimmy use the bottom ones? I think I am going to have to do some modifying to get these to work.
Is the 2WD a leaf spring rear? If so, the (top) 4X4 ones will be what it needs. WES
It's coils. I had to trim a tiny amount from the flanged part, it was hitting the rear body mount. The body has been off before, and they used a couple of big washers, one is interfering with the bumper bracket, not a big deal. They are on now. Thanks for the help!!
Good pics Wes
Which brackets work on swb leaf spring 2x4?
Bob |
