07-10-2005, 12:40 AM | #1 |
vortec engine question
I posted this in the 88-98 board as well, but I know a few of you guys run late model engines and may be able to help me out. I am putting a four bolt main pre-86 block into my 98 model z71 with a blown engine. I am planning on putting the heads and fuel injection on the pre-86 motor. I was told the 98 harmonic balancer would not work on the older engine. If this is true will the old style harmonic balancer line my pulleys up correctly? Will the flexplate from a th350 work for the 4l80e? I was told the 98 flexplate would not work. Also will the front cover/crank sensor bolt up to my block. Any other problems I may run into?
67 chevy stepside, 6 cylinder, three on the tree, small window. Currently in resto. |
07-10-2005, 09:26 AM | #2 |
I have just installed a 1996 Vortec in my 70. I used pulleys off of old small blocks, and they bolt right up to the vortec harmonic balance. I hope someone else will chime in on the balance compatability. Your question about the flywheel...I dont think yours will work due to a rear main seal change in 86-87(they went to a one piece). I have been suprised how almost evevy thing has bolted into place on my swap. Good Luck!
70 C/10 LWB 69 Cougar 68 Mustang 68 GMC 4X4 SWB |
07-10-2005, 11:58 AM | #3 |
He's got mean nasty FANGS!
A 98 is externally balanced 350, a pre 86 is internally balanced. You will need the right flexplate and balancer for your engine. I think (not for sure) the TH350 felxplate should work for hte 4L60E.
2004 K2500 Burb 1999 C3500 1985 Cutlass Supreme 1969 C-10 1967 C-10 Panel josh@67-72chevytrucks.com |
