Old 07-10-2005, 09:10 AM   #1
roadking
scratching my head ? engine stumbling
my engine acts like its almost running on 7 cylinders kinda out of the blue, 2000 miles on a gm crate with new everything. eldeblock 600 carb., edel fuel pump and intake, summit hei. engine was running fine, last thing i did to the engine was adjust the idle mixture srews, ran fine after that until i started one morning about a week later then it had the miss. heres what i"ve done since then. had ignition module checked, changed plugs. wire , cap, rotor, checked voltage to the hei, fuel filter clean, adjusted ims about 3 turns out, choke opens up properly, timing has not changed (10degree) seems to be getting plenty of fuel, engine is not smoking. i have not done a compession check but doesn't seem cylinder related. so im kinda scratching my head now, is there anything else i've i need to check? thanks
71 C10 SWB
BLACK AND WHITE
350 CRATE TH350
ENJOY LIFE
roadking is offline   Reply With Quote
Old 07-10-2005, 09:22 AM   #2
Gordo
Sounds like you have eliminated the ignition system, better do the compression test. Is this a steady skip or a random misfire?
1971 C10 swb stepside 350/700R4/3.73posi (retired as of 4/22/03)
1998 S10 short bed
2002 S10 Blazer
1942 Oldsmobile
1958 Massey Harris Pony
1951 Wife
Killingworth, Connecticut
May those who love us, love us, any of those who do not love us, may God turn their hearts.
And if God is unable to turn their hearts, may he turn their ankles so we may know them by their limping.
A man who works with his hands is a laborer; a man who works with his hands and his brain is a craftsman; but a man who works with his hands and his brain and his heart is an artist.
Gordo is offline   Reply With Quote
Old 07-10-2005, 10:14 AM   #3
Gray Ghost
Gray Ghost's Avatar
If it's random, check your ground and the wire to the distributor, before you do a compression test...mine was the ground and the power wire. It was dropping 500 rpm at will. Found the dissy wire almost apart (inside the harness no less) and wired to the alternator.
Kelly
'05 GMC Sierra SLE Z71
Bone stock except for new bed rail caps.
Gray Ghost is offline   Reply With Quote
Old 07-10-2005, 12:27 PM   #4
roadking
only thing i've noticed different is when i adjust my right side idle mix. screw in all the way it does not want to die out like before, the left side will die out if i adjust it in. what would be the procedure for checking and cleaning the IMS ?
71 C10 SWB
BLACK AND WHITE
350 CRATE TH350
ENJOY LIFE
Old 07-10-2005, 02:56 PM   #5
jhow66
jhow66's Avatar
Take mixture screw all the way out and and use air hose to blow out the passage. This wiil probably cure your problem as the idle passage is stopped up if it will not affect the idle speed.
56 Chevy Bel-Air 2dr. HT (purchased new)
71 Chevy Cheyenne SWB PU (502HO)
65 GMC short bed step--work in progress and my gofer
jhow66 is offline   Reply With Quote
Old 07-10-2005, 06:23 PM   #6
1STtimePRo'71
1STtimePRo'71's Avatar
-Cory
1967 2 Wheel Chevy
1STtimePRo'71 is offline   Reply With Quote
Old 07-10-2005, 10:29 PM   #7
roadking
i got a chance to blow out the ims, no more stumble ran great. reset ims to edelbrock recommendation ran fine for awhile then started to stumble again on road test. i'll blow out again tommarow and see what happens.
71 C10 SWB
BLACK AND WHITE
350 CRATE TH350
ENJOY LIFE
Old 07-10-2005, 11:09 PM   #8
Gray Ghost
Gray Ghost's Avatar
Have you checked your fuel filters? Sounds like trash is getting in.
Kelly
