Old 07-10-2005, 10:48 AM   #1
Chevy Muscle
< 69 Blazer
Chevy Muscle's Avatar
Another Rear Rollpan question (fleetside)
I feel stupid for asking this but I'm stumped.
I have a rollpan for my blazer that I started to install. I took the tailgate off so that I could weld this baby in and noticed that there might be a big problem....
.... (I didn't weld it in yet.... just screwed it in).
...... There doesn't seem to be a way to get to the bottom trunioin (sp?) bolt for the tailgate bracket if the rollpan is installed.
I don't want to weld this sucker in if I can't remove or replace the tailgate.
Am I missing something? Can you guys that have installed a rollpan tell me how to remove the tailgate (bottom bolt) after it's welded in?
Chevy Muscle is offline   Reply With Quote
Old 07-11-2005, 07:23 PM   #2
Chevy Muscle
< 69 Blazer
wow pg 3 already.
Anyone?
Old 07-11-2005, 08:18 PM   #3
Sweet72
Sweet72's Avatar
I had the same problem and decided to cut a rectangular piece out of the roll pan so I could get a wrench on the trunnion bolt, although you won't be able to turn it much at a time.
'72 GMC SWB C1500 Custom, frame-off in progress. 383 SBC, 9:1CR, Comp Cams XE262H, Scat internal balanced crank, Eagle SIR 6" rods, Keith Black dish pistons, Dart Iron Eagle 72/180 heads, Weiand Stealth intake, Stewart stage I water pump, Holley 4bbl vac sec, TH350 with B&M Shift Improver Kit. 12 bolt positraction.
Sweet72 is offline   Reply With Quote
Old 07-11-2005, 09:23 PM   #4
2low72
Same here. It makes it slower to get the tailgate off but I don't really take mine off that much for it to matter!
2014 GMC Yukon XL (Wifey's)
2004 Chevy Silverado Crew Cab Z71
2low72 is offline   Reply With Quote
Old 07-11-2005, 10:08 PM   #5
71swb4x4
71swb4x4's Avatar
Same here. You have to modify it, or not take the gate off.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs.
71swb4x4 is offline   Reply With Quote
