The pickup lean
So, If I installed a rear antisway bar would it get rid of some of the lean from my gas tank??? I know I can rearch the springs . How about I move my hanger shackle kit down one hole on the drivers side????
bob
1986 C10 Scottsdale 5.3, TH400 |
If it leans that much from the gas tank being full, I'm pretty sure there something else wrong.
Robert Current: 1986 SWB Silverado 4.3 / TH400 Past: 1985 SWB Silverado 305 / TH350 - sold 1995 1987 1/2 ton Silverado - FI 350 / 700R4 sold 2007 |
needin' money
do you have any pics, that might help us help you find the problem
SWB Stands for Short Wide Bed |
Well it's not that bad but I notice it. With a full tank it's down about and inch and the front pass side goes up 1/2. I figue I misght even get a little if I tilt the bumper a smidge. I'll get some pics and some measurements this week if I get my truck back. The tilt was there before the drop. I fugure with my lard but anf the gass tank was cousing the lean. For all I know it might not even be there with the vehicle in drive. I just see it every time I come up on the truck.
bob
Try using the other gas tank?? Maybe balance your weight and the gas??
Hmmm, I though of that but, I only have one gas tank. I don't feel like cutting in another door on the pass side.
bob
Two suggestions, neither of which I really like...
1) Install counter weights on the opposite side of the truck frame. Just bolt some steel plate or something. 2) Install some form of rear air-bag load leveling setup and just run more pressure in the bag on the gas tank side of the truck. Personally, I'm thinking what C&C Chevy said at the beginning might be more on the mark... if it leans that much with a full tank of gas, something else is amiss. |
Sorry, I assumed you had dual tanks. I thought all 87's had dual tanks. My bad.
A cracked leaf spring would account for a sag on one side. And can be hard to spot.
Get a fat girlfriend
86 SWB 9.0 LITER T-400-OD 4.11 eaton-4/5 drop Best 1/4 12.51 @112mph no traction ![]() |
Parts and more parts
chubby chix will balance out that awful lean on that truck. Put one on the opposite side of the tank and you are good to go.
Ya a chubby chick would work cause I'd have everything I own in there too. IF the wife didn't kill me first.
CC no issue. I'm sure I've seen this before with chevy trucks. I just don't understand why the moved to tank to the driverside in the first place??? I even though of the blazer tank route. I can use more capacity. Just a lot of work there. I'll check for spring issues. So a anti-swap bnar won't help? bob
Born a Chevy Man
I just checked my '86 and with a full tank of gas on left side only,(D-Side) it does not lean at all that I can see. I think it must be a spring issue. I never use my right side tank. Do not even know if it works. Too cheap to fill both tanks. $$$
John or 86 (Viet Nam combat Vet-BIG RED ONE) '65-'66 *1986 Chevy SWB Silverado *1984 Chevy Longbed Silverado New Kia Sportage (Wife's car and she loves it) ![]() ![]() If you can read this, YOU NEED TO THANK A TEACHER! If you can read this in ENGLISH, PLEASE THANK A SOLDIER! ![]() GOD BLESS AMERICA AND BLESS OUR FIGHTING TROOPS |
#13 |
Insert Witty Text Here
My '86 has no noticeable lean regardless of what tank is full or empty. I use both tanks. I vote for the "something is wrong with your suspension and you need to fix the problem rather than the symptom" option.
![]() Slonaker EDIT: Just for grins, have you checked the tire sizes? I once bought tires at Pep Boys and they put two of one size on the left and two of another size on the right. They were only off by one size, so the difference was not notieable, but it made it lean noticeably. I also had a place put 3 of one size and a fourth of a different size on a car. That one leaned, too. Idiots.... Last edited by Slonaker; 07-11-2005 at 12:06 PM. |
