Old 07-10-2005, 08:15 PM   #1
crews
It just doesn't matter
Fuel guage issues...
OK gang- I have the poly tank kit installed and I have the new sending unit wired up- all was working great until about an hour ago. Guage was working correctly, and now it reads nothing. Ground is still intact and no visibly loose wires...Is it really possible that the sender just shot craps? Any other ideas? Just for reference, the guage did not work prior to the new kit being installed.
What do I need to be looking for?
05 Chevy Silverado..... A rogue BMW guy....
If you don't like me- TAKE A NUMBER; There are people ahead of you!!
crews is offline   Reply With Quote
Old 07-10-2005, 09:58 PM   #2
byrd
Union Electrician
byrd's Avatar
The resister probably went out. It's the ceramic thing attached to the metal studs on the back of the gauge. fixagauge.com or something like that sell the resistors for about $10 and it's an easy fix if that is what's wrong with your truck.If you have access to a digital multimeter and can measure resistance value of the resistor, it should be around 70 ohms iirc Randy
69 Custom-10 SWB FLEETSIDE 350/350 TH Dropped 3.5/5.5"
Help support the board->HERE
Board vendors -> Vendors list
Zip:40272
Big Sandy Survivor...
We cannot choose the way we die, but we can choose the way we live
If you can't fix it with a hammer, you've got an electrical problem.
I think Congressmen should wear uniforms like NASCAR drivers so we could identify their corporate sponsors
byrd is offline   Reply With Quote
Old 07-10-2005, 11:30 PM   #3
crews
Thanksbyrd! I remember those stupid little ceramic resistors now!! Thanks for the info...I will try that tomorrow..
Old 07-11-2005, 06:04 AM   #4
4x4Poet
Recheck that ground? Did you scrape the metal clean and bare where the ground is bolted? Is the metal that the ground is affixed to also grounded well? Trace the ground path back to the battery.
'71 GMC K20 Suburban, '71 GMC K10 Suburban, '72 Chevy C10 CST Suburban, '72 Chevy K20 clunker pickup.
4x4Poet is offline   Reply With Quote
Old 07-11-2005, 08:44 AM   #5
toddtheodd
The oddest Todd around
toddtheodd's Avatar
Doesn't that little resistor keep the needle from jumping around so much? Or am I thinking of something else?
Todd
"The greatest pleasure is to vanquish your enemies and chase them before you, to rob them of their wealth and see those dear to them bathed in tears, to ride their horses and clasp to your bosom their wives and daughters." Ghengis Khan
IIOY???
toddtheodd is offline   Reply With Quote
Old 07-11-2005, 11:18 AM   #6
crews
Yes the ground wire was new. It is grounded to one of the main frame cross members. Everything was scraped and prepped for ground. I will start tracing the path later today.
