Old 07-11-2005, 10:44 AM   #1
72MARIO
72MARIO's Avatar
Bleading Brakes. Help !
Well I have just finished all the lines brand new everything. I am using dot 5 fluid.
Anyway I epoxy primed and painted my MC then installed it. Filled it up and opened the bleader screws. The front came out in a few minutes. So I am ready for a helper to push the pedal out while I open the bleader screw and close it before they let there foot up. But the rear will not run a hour later and still nothing. Did I have to bench blead the MC ?
Any way to get around this ?
Thanks for any tips.
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair
http://67-72chevytrucks.com/vboard/s...d.php?t=625017
1967 C/20 6.0/4L80 Roofing Truck
1990 V2500 Suburban "Plow Truck"
2005 TAHOE DD
72MARIO is offline   Reply With Quote
Old 07-11-2005, 12:44 PM   #2
Striker169
Car O'Holic
Striker169's Avatar
Yes you always have to bench bleed the MC you can do it when its installed it just requires more pumping of the pedle
Striker169 is offline   Reply With Quote
Old 07-11-2005, 12:58 PM   #3
Fred T
Cantankerous Geezer
Fred T's Avatar
Try cracking open the line coming out of the m/c. Usually you can get fluid to flow there, if not do your bench bleed with that fitting. Have your helper push the pedal down, then open the fitting to release the air.
Fred
There is no such thing as too much cam...just not enough engine.
Fred T is offline   Reply With Quote
Old 07-11-2005, 01:11 PM   #4
68speedalert
Semi-Senior Member
68speedalert's Avatar
Since everthing is epoxied, find line plugs for the openings of the mc and just keep pumping the pedal until no bubbles come from the ports inside the mc (at the bottom of the resevoirs). The mc is now bled. I've had good success with gravity bleeding at the wheel cyl. Open them and let drip until a steady drip is seen. The plugs are available at auto parts stores.
Steve
'68 50th Anniversery LWB Custom Fleetside, '77 305 v-8, turbo 350, factory speed alert (still works), '71 drivetrain w/front discs. Some call it ugly yellow, others call it Ochre
'83 Jeep CJ-7, <80,000 miles, original owner
'04 Chevy Suburban, 4x4, 2500, 6.0 ltr, Predator Diablo programmer
'95 GMC K1500 Extended cab
68speedalert is offline   Reply With Quote
