07-11-2005, 11:50 AM | #1 |
Hydraulic Clutch Retrofit?
Has anyone here done a hydraulic clutch retrofit?
If so, what pieces did you use? Thanx, Bud |
07-11-2005, 01:51 PM | #2 | |
Bloo
i havent done it, but i have seriously considered it... the peices i was planning to use would be a bellhousing from about a 85-89 4 speed (these are removable like the older ones, its just a SM465), and order a slave and master cylinder for a "89 chevy k2500, new body style, 4 speed, 350"... the reasoning behind this is they are metal, and the resevoir is attached to the master cylinder, not seperate like the old body style. youll also need a throw out fork, throw out bearing, and i think the clutch is different. if you have the old type of starter that bolts to the bellhousing, youll also need a new starter.
so, in short, here is a list
i think thats all i can think of that is different that youll need
ASE Master Certified-GM Trained-Mechanic 1968 Chevy C30 157" WB Wrecker 1969 Chevy CST/10 SWB 1971 Chevy Custom/10 (first truck) 350, NV3500 5 speed 1971 Chevy K20 Custom Camper 4x4 350 TBI, SM465/NP205 1974 Chevy Custom Deluxe/10 1979 Chevy Custom Deluxe K10 farm truck beater 1989 Chevy K2500 Quote:
07-11-2005, 09:21 PM | #3 |
huh?
Member Yukon Jack has done it, you may want to contact him.
Someday when I'm lonely, Wishing you weren't so far away, Then I will remember Things we said today. RIP El Jay |
07-11-2005, 10:26 PM | #4 |
Questionable
Don't you hafta convert to hydraulic clutch with the LS1 conversion?
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link) I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM. |
07-12-2005, 09:04 AM | #5 |
Good post! I have been considering this as well. Blue_71, thanks for posting all of that info. Do you know what size flywheel the 85 - 89 4 speed bellhousing will accept (153 or 168 tooth)? I have ran across other information on this subject and have been told that they are different from small block to big block. Anyone else have more info, or even better yet any pictures??
67 short wide 355ci 3 on tree 69 short wide 250ci 3 on tree 68 long wide 283 3 on tree 72 2wd Blazer project 454 5 speed |
07-12-2005, 06:32 PM | #6 |
Bloo
thats a good q chevy farmer, i dont really know though. i would think that any flywheel would fit in it, but im not sure
another thing i forgot to mention-- you can also use a bellhousing from a NV4500 i *think*, its removable just like the SM465 is, and has the correct engine bolt pattern.. not sure if the bolt pattern to hook to the trans is the same though |
07-12-2005, 09:53 PM | #7 | |
1990 subaru legcy (daily driver) 1987 Toyota 4runner (weekend toy) 1968 C30 flatbed dually 1970 C10 longbed stepside (in pieces) 1976 Dodge Dart 1963 Dodge Dart |
