Old 07-11-2005, 01:37 PM   #1
C&C Chevy
C&C Chevy's Avatar
Brake problems
This is for my wifes car, but I figure hydrolic brakes are hydrolic brakes, right..
The pedal goes soft(to the floor sometimes!) after the car has been driven awhile. I've bleed the brakes (4 disc) and they work fine for awhile after start-up but then go soft. What's up?? I'm thinking a weak brake line, but how do I find out??
btw, the brakes always have pressure, I'll pull up to a stop and the pedal will start losing pressure and the car will roll if I'm not careful.
Robert
Current:
1986 SWB Silverado 4.3 / TH400
Past:
1985 SWB Silverado 305 / TH350 - sold 1995
1987 1/2 ton Silverado - FI 350 / 700R4 sold 2007
C&C Chevy is offline   Reply With Quote
Old 07-11-2005, 02:52 PM   #2
SSC's76
No No
SSC's76's Avatar
Well a leak some where would be a sign. What kind of car is it? Yes it makes a difference. an example would be; If it's an ABS eqquipt GM with no signs of fluid leakage then the ABS unit has a stuck valve.
1976 Custom Deluxe SWB Med FMB.3/4 Drop.
Gen VI 454, Muncie HD 3 speed With Modified OE Hurst Shifter, 3.73 12 bolt, GMPP HO roller cam, Hooker headers, Performer intake with modified Q-jet, Accel distributor. Best 1/4 12.3 @108. Funnest run 19.84 @88 full 1/4 mile burn out.
1997 K1500 ext cab 5.7 stock except muffler
SSC's76 is offline   Reply With Quote
Old 07-11-2005, 03:21 PM   #3
hobbz
hobbz's Avatar
do you loose fluid in your resvior but not see any leaks? if so prolly the master cyl
hobbz is offline   Reply With Quote
Old 07-11-2005, 03:31 PM   #4
C&C Chevy
C&C Chevy's Avatar
It's a 93 Accord. The ABS light has always come on but I was always told that it doesn't affect the line pressure, so I never got it fix. And this just started a few weeks ago, and the ABS light has been coming on for years.
I did have the master cyl. replaced a year ago. Maybe something there??
The pedal doesn't go straight to the floor like there is air in the caliper. It just kind of eases on down. lol..
Robert
Current:
Past:
Old 07-11-2005, 05:08 PM   #5
apstguy
LED King
apstguy's Avatar
Probably a bad master cylinder.
Tyler
1985 C10 305 w/ Bowtie OD TH700R4 3.42 LSD 202,000 miles
2006 Ford Focus ZX3 5-speed Stick
2016 Chevy Spark EV
Gone: 2002.5 VW GTI 24v VR6
Gone: 2008 VW R32
apstguy is offline   Reply With Quote
Old 07-11-2005, 05:51 PM   #6
old Rusty C10
Robert Olson Transport
old Rusty C10's Avatar
prolly a bad master cylinder.. the abs unit is different that wont make the fluid leak ... and if you put a rebuilt in there its only as good as the rebuilder and kit put in there... sometimes a new one aftermarket is almost as cheap as a rebuilt one so check that out
Bob
1951 International running on a squarebody chassis
"If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board"
http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!)
PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport
Live each day to the fullest.. you never know when fate is going to pull the rug out from under you...
I hate cancer!!
old Rusty C10 is offline   Reply With Quote
Old 07-11-2005, 08:23 PM   #7
red86chevy
I also have a '93 Accord and I had the same problem at around 110,000 miles. The master cylinder was bad. Hope this helps.
Jeremy
86 c-10 383 w/ sportsman II heads comp 286h cam Edlbrock RPM Performer intake Holley 750 th350 w/2400 stall 3.73 gears with powertrax No-Slip posi unit. Just broken in good. Will get a 1/4 time this week.
red86chevy is offline   Reply With Quote
Old 07-11-2005, 08:28 PM   #8
C&C Chevy
C&C Chevy's Avatar
Does a bad master cylinder account for the brakes not working only half the time. I was thinking maybe a brake line was getting hot, as the car warmed up, and it started to fail. ???
Robert
Current:
Past:
Old 07-11-2005, 08:35 PM   #9
C&C Chevy
C&C Chevy's Avatar
Thanks 86. I guess that's the problem. The car has 170,000 on it, so I'm not to worried about putting alot of $$$ into it. Probably see if they can put another used cylinder on.
Robert
Current:
Past:
Old 07-11-2005, 09:27 PM   #10
red86chevy
C&C Chevy mine has rear drum not disc. I'm not sure why it would only do it when hot though. Mine just started one day and did it hot or cold. I would still bet It's the master cylinder though.
Jeremy
Old 07-12-2005, 05:53 PM   #11
Zilverado
Zilverado's Avatar
Hey here's an original suggestion.... Master Cylinder...
OK, so it wasn't original.
Zilverado is offline   Reply With Quote
