blower motor running all the time
My dad just bought a 79' chevy silverado with a big block. Does anyones blower motor run all the time with the key on power ????
mine does that too, don't really bother me though
Stepsides RULE
It's a safety feature by GM to keep air circulating through the cab.
This topic gets thrown around alot ![]()
1981 Chevy C10 Custom Deluxe Stepside 350 V8, headers, side exhausts, 3-speed auto SOLD 1980 Chevy C10 Custum Deluxe Stepside 305 V8, Edelbrock Performer Intake, Edelbrock 1406 600CFM 4-barrel, TH350C. Bent rod. SOLD 1984 GMC Sierra Classic Longbed 6.2L Diesel SOLD 2009 Kawasaki KLX-250S too many mods for this signature 1999 Honda Accord EX 4-cylinder, 17" Motegi Wheels 215/45/17 Sumitomo tires, Tein S-Tech lowering springs, KYB GR2 shocks, Acura TL 20mm rear swaybar, debadged, blackhoused headlights, Short-Ram Intake Cardomain of the Accord |
thanks sorry to sound like a newbie.
RapidRide2:
....................These guys wouldn't pull your leg.............would they.. .................Nahh!!.................... The switch is probably screwed up..........maybe.....????? My wipers go on by themselves.......every once in a while.........turned on by aliens I suspect..............this is not the first truck this has happened to.... .......is it a plot???.........should I be wrapping my wiper switch in tinfoil, like the tin foil lining that I have in my hat??........will that keep the alien thought and energy waves out......WOW.....I ..can ....feel...them.... ![]() ..................It sure seems to work......jeezs....I ....hope ...so ![]() Just my .02 ![]() Last edited by GMC1tondually4dr; 07-11-2005 at 07:06 PM. |
#6 | |
Stepsides RULE
"The only dumb question is the one not asked." - Some Wise Dude
So you were kidding about the safety feature right???
No, It was done to prevent noxious gasses from accumulating in the cab. Mine does it too.
Happy to be here
![]() Join Date: Mar 2000
My 77 does it too. If they key is on, the fan is running.
GMC1tondually4dr can I get a hit of what ever it is you are smoking.... ![]()
N2TRUCK:
....................Yeahhhhhhhh...................but ........................... ......It'll................cost..........ya......................welllllllllll........... maybe not ...........THEY (you know who) WILL KNOW........ not enough...............tinfoil......................aaughhhhhh....... ![]() ![]() ...But seriously.....I have had a 1977 'Burb w/a SBC, a 1979 'Burb w/a 454, and currently a1991 'Burb w/a 454 and a 1986 Crew Cab Dually w/a 454. NONE of them ran or run the fan without it being turned on. Just my .02 ![]() Last edited by GMC1tondually4dr; 07-12-2005 at 01:33 AM. |
Born a Chevy Man
Mine started doing that and it was the (I think they called it a relay) where the wire plugs into. Chenged it out and now works fine (like it is suppose to).
John or 86 (Viet Nam combat Vet-BIG RED ONE) '65-'66 *1986 Chevy SWB Silverado *1984 Chevy Longbed Silverado New Kia Sportage (Wife's car and she loves it) ![]() ![]() If you can read this, YOU NEED TO THANK A TEACHER! If you can read this in ENGLISH, PLEASE THANK A SOLDIER! ![]() GOD BLESS AMERICA AND BLESS OUR FIGHTING TROOPS |
www.73-87chevytrucks.com
![]() Join Date: Dec 1999
The blower fan running is a feature of the flow-thru power ventilation system on the trucks.
Chris Lucas 1973 Chevy C-10 1978 GMC Jimmy (2WD) - SOLD 1987 R10 twin turbo LS 1991 R3500 SRW CrewCab 1985 K5 diesel swapped project 1989 K5 2WD conversion w/ Vette susp Project Captkaos Customs 73-87chevytrucks.com |
#13 |
No No
Mine has always done it. GM use to make an updated HVAC control module to eleminate the fan running. Two different ones Ive seen were a cheap resistor that elimitated low function "solder in, low off" and a whole new controll unit. If your hunting around the bone yard sometimes you can come across one of the two. Ive never seen one on a truck still one the road maybee the noxious gasses from the fan not running caused a crash.
1976 Custom Deluxe SWB Med FMB.3/4 Drop. Gen VI 454, Muncie HD 3 speed With Modified OE Hurst Shifter, 3.73 12 bolt, GMPP HO roller cam, Hooker headers, Performer intake with modified Q-jet, Accel distributor. Best 1/4 12.3 @108. Funnest run 19.84 @88 full 1/4 mile burn out. 1997 K1500 ext cab 5.7 stock except muffler |
#14 |
Born a Chevy Man
I think my situation was a little different. Mine ran even when you turned the truck off. Had to unhook the battery. That is when I found out it was the relay. Did not know blowers were on all the time when the key was on.
#15 | |
#16 |
..Yep ...stone stock..... the Dually has a Master Hauler interior.
My Dually and the '79 Burb window wipers, would for no apparent reason, cycle for a time or two , then shut off never to be flicked again until needed... I have heard from other '77 to '87 owners having the same problem. No big deal, we figured the .........aliens did it. Just my .02 ![]() Last edited by GMC1tondually4dr; 07-12-2005 at 11:44 PM. |
#17 |
I have seen non-A/C trucks without the blower feature thats all. And the intermittent wiper sweep is usually caused by a delay module going bad.
#18 |
i have the wiper problem as well, first started out where it wouldnt shut off when turned on, replaced the switch.. now it just cycles every 12-15 min... i dont notice it anymore...
Jon 1982 Chevy Silverado 350/th350.... RETIRED 1993 Jeep XJ 2 door(Cherokee) 4wd 4.0ltr/AX-15 (5spd)/NP231 .... Oklahoma Roll Call |
