07-11-2005, 05:43 PM | #1 |
Fan shroud info clarification
Here is information I recieved from ECE Technical Support. Does this mean that the distance between the radiator and motor is an inch less or the fan shroud is an inch closer to the motor?
---------------------------------------------------------------- Tim, the only difference between the two shrouds is the A/C model is about an inch shorter between the radiaitor and motor. ----- Original Message ----- From: Tim Olmstead To: techquestions@earlyclassic.com Sent: Wednesday, July 06, 2005 11:48 PM Subject: Technical Question Hello ECE Tech, I need to purchase a fan shroud for my 1970 C10 2WD 350 w/AC. I noticed you have two a different fan shrouds, one for w/AC (11-3901443) and one for w/o AC (3889079). What is the difference in the fan shrouds? Tim Olmstead
Got bored, sold everthing. Got bored, looking for a 1960-66 C-10. Want to build my last truck. |
07-11-2005, 06:18 PM | #2 |
its all about the +6 inches
IIRC, A/C trucks came with a fan clutch, which would move the fan forward....an inch or so. This would make the space from the fan to the rad smaller, and the shroud needs to be an inch shorter too. You want your fan blades to be 1/2 in and 1/2 out of the shroud for max cooling.
07-11-2005, 06:43 PM | #3 | |
Longhorn Man I am not disagreeing with you since I don't have any hard facts but it would be nice to have this information for others in the future. I can make things work but I would rather understand why and how they work.
07-11-2005, 07:32 PM | #4 |
Like I said...IIRC....I am commonly wrong on details.
07-11-2005, 07:37 PM | #5 | |
07-11-2005, 07:40 PM | #6 | |
The LuvShack Garage
I Re Call
Owner/Op: "TN Classic Transport Carriers" The Toy: "Square Vette" 72 Hybrid Blazer Toy Barn: "LuvShack" 40 x 60 x 20 Shop Tow Piggy:"Maddy" 88 Silverado 3500 Hauler: "Feathers" 14 Aluma 8218T |
07-11-2005, 07:41 PM | #7 |
lol...OK
If I Remember Correctly IIRR If I Remember Right |
07-11-2005, 10:18 PM | #8 | |
Final answer from ECE Tech. And the answer does not concern the fan or clutch, sort of. ***No, exactly the opposite. The A/C shroud is shorter, leaving more room for compressor/crank pullies, belts etc.*** ----- Original Message ----- From: "Tim Olmstead" <tim@cwo.com> To: "Tech Questions" <techquestions@earlyclassic.com> Sent: Monday, July 11, 2005 2:51 PM Subject: Re: Technical Question ECE Tech, does this mean the A/C fan shroud is an inch closer to the motor? What is the reason for the difference in the depth of the fan shrouds. Does it have to do with fixed or clutch fans? Thanks for your time and effort. Tim Olmstead Very Hot Sacramento
07-11-2005, 10:20 PM | #9 |
if the fan sticks out a foot from the engine, what does it matter if there is another belt and a compressor mounted up over a valve cover?
07-12-2005, 02:20 AM | #10 | |
07-12-2005, 09:57 AM | #11 |
The show is dream car garage.
Saskatoon, Saskatchewan Canada |
07-12-2005, 01:27 PM | #12 |
Not a bad nut after all..
My theory is that AC trucks had 4-row radiators which are bigger hence requiring a shorter shroud.
07-12-2005, 03:49 PM | #13 | |
Next question is what is the differnece of the installed length of a fixed and clutch fan?
07-12-2005, 05:52 PM | #14 |
don't ac trucks have a long water pump, and non ac trucks have a short water pump, hence the 1 inch difference. that's how the p/o of my truck explained his home made alternator bracket.
07-12-2005, 06:07 PM | #15 | |
20' Daredevil (Ret)
07-12-2005, 06:16 PM | #16 | |
20' Daredevil (Ret)
07-12-2005, 10:22 PM | #17 | |
07-12-2005, 10:58 PM | #18 | |
tomatocity, i wasn't directing that at you....just in general...I know you were just relaying the info..my fault, I need to reword my thoughts sometimes. |
07-13-2005, 12:27 AM | #19 |
tomatocity, i wasn't directing that at you....just in general...I know you were just relaying the info..my fault, I need to reword my thoughts sometimes.[/QUOTE]
Hey no offense taken. Glad to share whatever input we have. Better than talking to ourselves (man that would be a boring conversation for me).
07-13-2005, 12:28 AM | #20 | |
07-13-2005, 02:27 PM | #21 | |
20' Daredevil (Ret)
07-14-2005, 02:34 AM | #22 | |
07-14-2005, 10:23 AM | #23 |
20' Daredevil (Ret)
Tomatocity, I should add that my shroud does not look like the one in your pics. I don't have a digital camera, but I'll try to describe it. Rather than the sudden transition a couple inches from the fan opening, mine flows smoothly from the attachment points to the fan opening. HTH!
07-14-2005, 01:29 PM | #24 | |
07-14-2005, 01:33 PM | #25 |
Yes 4X4 have the engine set back further
For every person with a spark of genius, There are a hundred with ignition trouble. 70 Short/Step |
