07-12-2005, 12:35 AM | #1 |
suspension upgrade?
I've got a 70' 3/4 ton LB. I read somewhere that one could take the disc brakes off a 73' or later and would fit right on my 70' spindles,as long as i used late model tie rods. Even by buying a Chevy interchange manual i still cant confirm this swap will work. If anybody has done this or knows anything about it PLEASE let me know. You'll be saving me my sanity and about $800.
07-12-2005, 12:54 AM | #2 |
I believe that the ball joints are different between the years too, not sure about the 1/2 ton and 3/4 ton interchanging.
07-12-2005, 01:29 AM | #3 |
Can use 71-87 Spindles, backing plates, caliper brackets, ball joints, center link, inner and outer tie rods.
This will all mount up using your original C-20 A arms. Also - be sure to get a proportioning valve from a disc/drum truck - (brass block behind x-member). Good luck. |
07-12-2005, 01:37 AM | #4 |
even though 69-70 ball joints are rivited in and 71-87 arent, my A arms will accept them?
07-12-2005, 09:57 AM | #5 |
The top balljoints are riveted on all of the older chevs, but the bottom arms have pressed balljoints. the balljoints are a direct swap, as Rodder4hire has posted L
http://community.webshots.com/user/hotrodhorn |
