Old 07-12-2005, 07:55 AM   #1
69ShortStep
69ShortStep's Avatar
Cab Mounting Washers - Need Help!!!
I am picking up my cab tonight. I bought an energy suspension cab mount kit which I thought was complete.
It refers to factory washers ( some with a square insert ) on the front and rear mounts. Are these a must or can I just use any washers?
If I do need the factory washers, where can I get them ( Part #) ? If not, what is the size of the washers I need?
Thanks for your help in advance!!!
69ShortStep is offline   Reply With Quote
Old 07-12-2005, 07:36 PM   #2
JimKshortstep4x4
Talking
We get very large washers from "Fastenal" which is an industrial fasteners company. For the tube we cut off the right length of 1/2" conduit. We have also made washers out of square plates 1/8" thick with a hole in the middle.
The factory washers that I have seen, have the tube extruded with the washer as a one piece unit. I have also seen the tubes welded to the washers but when the bolt is tightened down the tube will not move against the washer so what we do does work.
Jim
