Old 07-12-2005, 12:04 PM   #1
nartkers
nartkers's Avatar
'85 to '70 interchange
I know that this has been done before, but I need to ask again.
I have disc brakes (rotors, calipers) from an '85 C10. I want to put them on my '70 C10 without using the custom tie rod adaptor.
Can I use the centerlink, inner and outers from the '85? What other parts will I need from the '85. I still plan on using the control arms from the '70 since they are like new.
nartkers is offline   Reply With Quote
Old 07-16-2005, 03:21 PM   #2
69 longhorn
If you use the centerlink, tiedod assys, & balljoints from the 85, it should all bolt on. The 85 has a metric steering box, so you may need the pitman arm also. best of luck,69L
http://community.webshots.com/user/hotrodhorn
69 longhorn is offline   Reply With Quote
Old 07-18-2005, 09:39 AM   #3
nartkers
nartkers's Avatar
thanks for the reply. what do you call those pieces that bolt to thr fram and support the centerlink? I will need those also right?
Old 07-18-2005, 10:44 AM   #4
69 longhorn
That would be the idler arm(bolts on pass side, with 2 bolts?). Im not sure if there is a difference, but its best to pull all the steering link pcs from the same truck......it will save on a lot of confusion trying to match parts.
Old 07-18-2005, 01:30 PM   #5
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
The later idler arm will bolt right into the earlier truck too. Take it all, side to side, and you won't need to buy any special parts.
Old 07-18-2005, 01:37 PM   #6
nartkers
nartkers's Avatar
yeah I did not have good luck with the special custom tie rod adjusting sleeve. It seems like it is too long to allow for proper alignment.
