How much header clearance?
I dropped in my engine and I have between 1/8 and 3/16 or so of clearance with the engine mount. Do I need to shim with some washers? Im thinking this wont be enough clearance when the engine torques or whatever else.
68 Chevy 383/350 w/shift kit, 380hp/425ft-lbs, 4.5/5 drop, 17" TT2s 64 Cadillac Sedan DeVille |
Questionable
I realize this won't be much help, but with my inline 6, I have less than 5mm of clearance between my headers and the motor mount.
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link) I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM. |
So do you have any problems?
Questionable
It's not a daily driver. The headers interfere with my clutch linkage (Z-bar), throttle linkage.
The engine runs without problems, but I haven't driven it so I don't know what would happen if I hit a bump. I have no problems revving the engine. But with no exhaust, yet (headers only) it sounds like a freakin motorcycle gang in my garage.
I think you are going to be really close. But you might get away with it. Give it a try unless they are ceramic coated then you may not want to chance chipping the coating.
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair http://67-72chevytrucks.com/vboard/s...d.php?t=625017 1967 C/20 6.0/4L80 Roofing Truck 1990 V2500 Suburban "Plow Truck" 2005 TAHOE DD |
They are ceramic coated so I want to be sure I have enough clearance. How much clearance do I need? Ill just stick some washers in b/w until I can get what i need.
Pat, may I ask a couple ??? ?
What engine do you have, v8? Which side (if not both) is close? Which part of the motor mount? Tower I'm assuming.
'72 C10 lwb 454/TH400 |
I have a 383. I think its close on both sides. Its really close to the top of the tower, almost level with the framerail.
You should be fine on the driver side, but may have a little trouble on the pass. The 383 will have plenty torque and with rubber motor mounts may allow it to hit. Not sure of a great way to correct....
