07-12-2005, 07:52 PM | #1 |
HELP! Need 4.10 ring and pinion for HO72
I need a 4.10 ratio ring and pinion for an HO72. Shims would be good too although I think I can still get those new. The rear bearing race on mine is shot. Need my truck to get back to work as soon as possible. I may swap in a 14bolt rear but would rather keep the eaton if possible.
Thanks, Norris
86 Silverado C10 back to 305 power! 67 C30 Dually Dump, with 350 transplant, Rockhauler 05 Duramax 3500 "If at first you don't succeed, try a bigger hammer" Member of the 1-Ton club! |
07-12-2005, 08:41 PM | #2 |
I have a 4.56 ring and pinion if you cant find a 4.10 $50 + ride
07-12-2005, 08:48 PM | #3 |
Thanks Erick,
I really want to stick w/4.10's I take this thing out on the highway alot and 4.10's are bad enough. Also I got the center caps the other day. Thanks alot.
07-12-2005, 09:04 PM | #4 |
I do have a 4.10 with a locker attached to it for my 70 blazer that now has the HO72 rear in it,but not f/s hehehehe sorry
Glad you got the caps too....I will look for a set locally here...Later,Erick |
07-12-2005, 09:37 PM | #5 |
I have this http://207.44.196.117/vboard/showthread.php3?t=161992
I could get off of for 75.00 plus S&H... sorry, but no shims
Support The Board |
07-12-2005, 09:54 PM | #6 | |
That pinion shaft looks like it may be shorter than mine. Mine has a double ball bearing around it not a roller bearing. Do you know what the difference might be?
Thanks, Norris Quote:
07-12-2005, 11:23 PM | #7 |
"Ochre Ogre"
Check with Tommy Knotts on the board. I purchased the drums and hubs from him for my C30. There is a good chance that the 3rd member was a 4.10. He is located in West Virginia.
Bowtie Truck Stop Inc. Mid-West GM Truck Restoration Parts Supplier Your Key Parts, Auto Metal Direct, Dynacorn, and Goodmark dealer. like us @ www.facebook.com/BowtieTruckStop 1971 C-10 Suburban (Ochre) 1971 K-10 Suburban (Ochre) 1972 C-10 Suburban (Ochre) 1972 K-20 Suburban (Yellow- that just aint right!) Springfield, Minnesota 56087 |
07-13-2005, 08:24 AM | #8 |
i still have 3rd member.i have not checked on ratio.$50, the money will be donated to this board ,thanks to da burb and I.
07-13-2005, 02:19 PM | #9 |
Found one locally, Thanks guys!
