07-12-2005, 09:49 PM | #1 |
Help with TH350. Short vs. Long Shaft
OK, I believe that my TH350 (which needs replacing due to it being blown) is a long shaft. Is this a common shaft (vs. a short shaft) for our trucks
I'm looking at an Ebay purchase CLICK HERE I don't think that I need a new converter, cause the one in my old tranny is hopefully good. Any thoughts folks?
'71 Chevy C-10 - Current '62 Imapla SS - Traded for my current '73 Nova Hatch - traded for ATC-350X '73 Chevelle Deluxe - First car (R.I.P) DEERFIELD, MA |
07-12-2005, 09:53 PM | #2 |
68cst_ss490
go with the long shaft, short shaft trannies are for cars generally. unless of course you engine is sitting in the inline 6 position than the short shaft will work.
ALWAYA ALWAYS replace the converter.....if there are filings stuck in it they will get pumped from the converter directly into your new trans. unless you get the converter flushed out completely. just my 2 cents
Dean edmonton,canada a winter wonderland 2005 Chevrolet Avalanche LT cold air intake, performance exhaust, Comp cams cam, jba shorty ceramic headers. http://www.cardomain.com/ride/3090973 |
07-12-2005, 11:05 PM | #3 |
its all about the +6 inches
these trucks came with short shaft trannys in the 69 - 782 equipped with the 350. I'm not sure if it was 73 or later when they moved to long shaft.
However, long shaft trannys are way more common and it makes it easier to do the one piece shaft everyone wants. Other than that, there is no reason to use one over the other. If your old tranny is junk, so is the converter. |
07-12-2005, 11:13 PM | #4 |
"Ochre Ogre"
the short 6" tail is correct for this vintage.
Bowtie Truck Stop Inc. Mid-West GM Truck Restoration Parts Supplier Your Key Parts, Auto Metal Direct, Dynacorn, and Goodmark dealer. like us @ www.facebook.com/BowtieTruckStop 1971 C-10 Suburban (Ochre) 1971 K-10 Suburban (Ochre) 1972 C-10 Suburban (Ochre) 1972 K-20 Suburban (Yellow- that just aint right!) Springfield, Minnesota 56087 |
07-13-2005, 11:15 AM | #5 |
There are three 350 trans. 6"-9"-12"
1980 Chevy Shortbed Pickup 1969 Z28 engine Turbo 350 |
