Just drag it
Gauges dont work
I have a question. My gauges/gauge lights don't work they did untill I cut a little portion out to fit my air gauge where the clock is. Also my voltage gauge only has 2 prongs in and then a hole. Is that right?
Sounds like you may have damaged the circuit board (for lack of a better term) when cutting the hole. Remove the entire cluster and check for broken traces on the flexable circuit board.
Yes, that is normal for a voltage guage. |
