Old 07-13-2005, 11:42 AM   #1
Lobo'74
Lobo'74's Avatar
HEI ignition modules failing
My HEI ignition module dies about every 11 to 12 months. I called the PO on this as he had done the rebuild on the engine. He said he bought the HEI distributor from a chain auto parts store (like Advance Auto) and it had a lifetime warrenty. He just took the whole distributor out when the ignition module failed (yearly) and took the distributor back to the auto store and got a new one.
I found that he had wired the HEI to the tail lights circuit and thought that was the problem. I thought that without a "pure" 12-14 vdc source the module would burn itself out regularly (like it was doing). I rewired the HEI with heavy gauge wire to the unfused block on the stock fuse block. Truck ran great for six months then just didn't have the power it should. I pulled the plugs and found they were VERY, VERY fouled. I got rid of the Bosch platinum plugs and went to NGK plugs. Truck ran great for six months then was hard to start one day and impossible to start the next. Pulled the plugs. Fouled, but nowher near as bad as the Bosch were. Also pulled the HEI ignition module and it was bad.
I relpaced the NGK's with Autolite racing plugs and put in a "lifetime warrenty" aftermarket HEI module to replace the stock AC/Delco module that failed. Truck runs like a champ. Wanted to go out and smoke tires a little but with my sick tranny I am leaving Truck in the driveway for now.
Could the plugs fouling put more of a load on the ignition module and cause it to go bad? If so then I just keep playing with plugs until I get a set hot enough to not foul but cool enough to not allow post shut down run on or detonation, right?
If the plug fouling would not cause the ignition module to go bad what am I missing? Why do these things quit annually? Is it just to make sure I don't miss the annual anniversary of when I bought it?
Any thoughts?
"Truck"
'67 small window
'79 350 .030 over, LT1 "clone"
Lobo'74 is offline   Reply With Quote
Old 07-13-2005, 12:36 PM   #2
shifty
Questionable
shifty's Avatar
Ignition modules often burn out because they're not properly grounded.
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link)
I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM.
shifty is offline   Reply With Quote
Old 07-13-2005, 12:38 PM   #3
shifty
Questionable
shifty's Avatar
Groudning example showing both wires you need to hook up to properly ground is here (scroll between the two posts):
http://67-72chevytrucks.com/vboard/s...15&postcount=7
Someone else stated there is a metal bracket for the second ground that is shown, but I've never seen one.
Old 07-13-2005, 12:46 PM   #4
70 shorty
Where's my beer?
70 shorty's Avatar
I thought I had heard (I am by no means an expert) that the modules basically worked or they didn't work, there really wasn't any in between. Can anyone back this up?
70 C10, shortstep, .30 over 250,Hurst shifted 3 spd parts hauler. Holley 390, Clifford Intake, Header, ported cylinder head, unknown bigger cam.
79 Corvette L82, 4 spd, black, red interior, headers, flowmasters, and unkown bigger cam.
'03 Grand Cherokee Laredo, 4.0 4x4 daily driver. 165K miles, and runs great
'08 Tahoe LTZ 4x4 155K
70 shorty is offline   Reply With Quote
Old 07-13-2005, 12:52 PM   #5
hotrodmtodd
'Burban Legend
hotrodmtodd's Avatar
The Key
Heat is the #1 killer of ig mods. Alot of people think they know better, and don't put the silicon grease on the back of the module. It is for heat protection and MUST be used. As Shifty mentioned, the ground strap in the coil MUST be clean, dry and serviceable, the module must be attached with BOTH screws, and the pin count and harness must be the same type. After that, there are many oddball things that can happen with ig mods, but heat protection and good grounds will solve MOST problems. There are many BETTER qualified folks on this board than myself that can help you with the oddball stuff. Good luck, Mike
'67 Chevy Iron City Beer Truck (9ft step)
'67 Chevy Panel Truck 467
'68 Short Fleet 305v6
'68 McLaren Ramp Truck
'68/'68/'70/'71 Burbs 292/366/402/454
'69 C-30 dump
'71 C-50 dump and church bus
'71 4x4 454
'72 Blazer (w/pop-up camper) $15 x-hooks
'66 Chevy II 194/Weber
'68 El Camino" 305v6
'69 Skylark 455 Buick
'70 Chevelle 427
'71 Cutlass W-31
'71 GTO 400 2x2
"The 51" Chopped '51 Chevy (409) my first car
OK Toad, we'll take 'em all... John Milner
hotrodmtodd is offline   Reply With Quote
Old 07-13-2005, 01:24 PM   #6
jhow66
jhow66's Avatar
here is the metal bracket and where it goes: Also make sure your engine is grounded to frame battery body.
56 Chevy Bel-Air 2dr. HT (purchased new)
71 Chevy Cheyenne SWB PU (502HO)
65 GMC short bed step--work in progress and my gofer
jhow66 is offline   Reply With Quote
Old 07-13-2005, 02:17 PM   #7
Russell
Professional Grade
Russell's Avatar
I bought myself a tube of Arctic Silver computer processor heat compound, never had a problem after that. The heat compound they give with the modules is cheap crap that is very sub-standard.
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap)
Russell is offline   Reply With Quote
Old 07-13-2005, 06:56 PM   #8
Smitty
Smitty's Avatar
Shifty is right on. I had the same problem, fortunately it happened near the shop I take it to when I'm to lazy to beat my head against the wall figuring things out. He found that there was a ground from the coil that was absent causing my problem. Haven't had it since!
Smitty
'71 Short Fleetside
Spring Valley, Ca.
Smitty is offline   Reply With Quote
Old 07-13-2005, 07:13 PM   #9
shifty
Questionable
shifty's Avatar
Todd's right about the heat - my truck overheated a while ago and knocked out my HEI entirely. Had to wait almost 45 minutes for the truck to cool before I could crank it back up again.
Old 07-13-2005, 09:45 PM   #10
hotrodmtodd
'Burban Legend
Arctic Silver
Russell: Can you tell me where Arctic Silver can be purchased? It sounds like a very good alternative to the "crap". What company makes it? Maybe I can find it that way. Thanks, Mike
Shifty: Thanks for the positive feedback, it's nice to have 17,000 friends to count on! Take care, Mike
'69 C-30 dump
'71 4x4 454
'70 Chevelle 427
'71 Cutlass W-31
'71 GTO 400 2x2
Old 07-13-2005, 10:01 PM   #11
Tanker350
www.arcticsilver.com
Tanker350 is offline   Reply With Quote
Old 07-13-2005, 11:08 PM   #12
hotrodmtodd
'Burban Legend
Thanks Tanker
I'll give that a try. Mike
'69 C-30 dump
'71 4x4 454
'70 Chevelle 427
'71 Cutlass W-31
'71 GTO 400 2x2
Old 07-13-2005, 11:10 PM   #13
shifty
Questionable
shifty's Avatar
It's normally used to act as a thermal transfer paste to take heat off of computer processors. It takes some break-in time before it works at 100%, but that shouldn't take long - one hour of constant driving should do it.
