07-14-2005, 12:06 PM | #1 |
She won't idle...any ideas?
Last night I replaced the leaky exhaust and intake manifolds without a hitch on the ’70 C10 with 250 L6. Exhaust doesn't blow into the engine compartment now and it sounds better. The problem I have created is the engine won't idle now. It just dies out if I let up on the accelerator. Nothing seems to have changed with the carburetor, or anything else that I can see.
Any ideas on what I should be looking for? Thanks!
------------------------------------- Tim '67 C/10, '04 Tahoe ------------------------------------- |
07-14-2005, 12:12 PM | #2 |
possibly vacume leak around intake?
http://www.picturetrail.com/jwill41 67 1/2 ton GMC short step side 68 1/2 ton Chevy long fleet side 72 1/2 ton Chevy Suburban 99 1/2 ton Chevy Suburban founder (and only member) of the primer/clearcoat club |
07-14-2005, 01:45 PM | #3 |
Questionable
Does it continue after the engine heats up? Do you have a manual choke (top right-hand side of the dash)?
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link) I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM. |
07-14-2005, 02:04 PM | #4 | |
07-14-2005, 02:38 PM | #5 |
~Rest In Peace~
try readjuting the carb now that a new intake gasket is place maybe the carb was set for when the intake had a slight leak and now thats is seal readjustment might need to be and check your timing again
is it fast ? it has a lighting bolt donut? B___H please, I can remove 90% of your so called "beauty" with a kleenex |
07-14-2005, 03:45 PM | #6 |
YES_____NO
I had the same problem on my 48 wilies that has a buick v6. the gasket under the carb. failed causing a major vacuum leak.
The damn thing would run great at about 1500rpm, but as soon as it went to idle it died....
People many not remember what you said or what you did, but they will remember the way you made them feel. - unknown Cause, remember: no matter where you go... there you are. - Buckaroo Banzai 1984 Help support the board |
07-15-2005, 10:25 AM | #7 |
Thanks for the input. I retightened the carb and manifold bolts and tweaked the carb adjustment screws a little. Was most likely vacuum and carb adjustment problem. It will idle now, but still needs a little more tweaking. Was most likely vacuum and carb adjustment problem.
07-15-2005, 11:38 AM | #8 |
One way to check for vacuum leaks involves a spray bottle of starting fluid or even WD40. With the engine running you can direct the spray at potential sources of leaks like the intake port gaskets, carb gasket, fittings, etc. The engine will change speeds when you spray around a leak. Usual caveats related to fire and extreme caution apply.
