Grand PooBaa Member
Spindles
I was wondering will 71-72 disk brake spindles will work on my 69 without modifcations. I just got a set of Rally wheels (will post pics later) and I need to go from 6 lug to 5.
Thanks |
Keepin an eye out
Yes. but you need to changes upper and lower ball joints to 71-2 and use inner tie rods for outer and get inner tie rods for 71-2. You will also need the adapter to connect the new tie rod configuration. Vendors have them...have fun
1970 Chevy C10 SWB 5.3 1996 Toyota Tacoma SR5 4x4 2007 Vespa GTS 250 Scooter ZIP 91351 |
Grand PooBaa Member
Dangit!!
Still sounds like extra work. I figured that would be easier than installing 73-87 spindles becaause 71-72 is the same bodystyle. |
Project Junkie! Fishing Poor!!
![]() Join Date: Dec 1999
You could always buy a set of 63-70 standard or drop disk brake conversion spindles. Then you could put the 5 lug setup on it. We have them in stock. then you can install them with your ball joints and tie rod ends. WES www.ClassicHeartbeat.com
On-line catolog Classic Heartbeat Pickup Parts WEHEPP@comcast.net Call us Toll Free (888) 338-2502 Like Us on Facebook No appointment necessary. 72 BB Chevy Custom Deluxe / Custom Camper 67 I-6 (Soon to be 5.7 LS1) Panel 68 BB Chevy Short Bed 72 6.0 LQ9 Short Bed Chevy 4X4 Olympia's fastest growing truck parts supplier. Olympia's home for Wayward Chevys Last edited by Classic Heartbeat; 07-14-2005 at 01:41 PM. |
Keepin an eye out
Ya I did my '70 and it was alot of work.
Also(forgot to add) you will need to change the master/booster to a 71-2 along with the correct prop valve and brake lines. It got a little costly even using used parts where I could. If you decide to tackle it and need help or advise PM me.
Grand PooBaa Member
I was trying to keep the cost down seeing that money is an issue right now.
But it seems to me that I might as well just buy them new. What part of So Cal do you live? |
Keepin an eye out
30 mi. N. of L.A. in Santa Clarita.
Grand PooBaa Member
Ok not to far from Magic Mountain, I have family in Stevenson's Ranch.
