Old 07-14-2005, 03:19 PM   #1
Already Gone
70+ ( Old Skool Club )
Already Gone's Avatar
Quick Question!!
This one should be easy to answer. I bought a new dash bezel and want to install it. My question is how do the headlight and wiper switchs come off . Do they just pull off from the front or do I have to crawl under the dash and push a relese button to get them off?
1992 K1500 GMC Suburban
" Circumsatances Do Not Change Responsibility "
" The Sky is not the Limit, Your Mind is." Marilyn Monroe ..
RIP Charlie Watts 1941 - 2021
Old 07-14-2005, 03:27 PM   #2
krue
Designated A-hole!
krue's Avatar
Turn your headlights on, then reach up under the dash and mash the button that is on top of the switch and finish pulling the nob off. Wiper knob is held on with a screw. May want to unhook your battery or the headlights might drain it.
Being stupid ain't illegal.
www.daveramsey.com
93 S-10 "Poppaw's Truck"
Old 07-14-2005, 03:39 PM   #3
Mongo
YES_____NO
Mongo's Avatar
also it is easier to turn the wipers to the on postion to get the little screw holding the knob on.
People many not remember what you said or what you did, but they will remember the way you made them feel. - unknown
Cause, remember: no matter where you go... there you are. - Buckaroo Banzai 1984
Help support the board
Mongo is offline   Reply With Quote
Old 07-14-2005, 05:06 PM   #4
byrd
Union Electrician
byrd's Avatar
You should also drop the column down a bit by loosening the strap under the column to give you about 1 1/2" more clearence to reinstall the cluser without scratching the bezel. Randy
69 Custom-10 SWB FLEETSIDE 350/350 TH Dropped 3.5/5.5"
Help support the board->HERE
Board vendors -> Vendors list
Zip:40272
Big Sandy Survivor...
We cannot choose the way we die, but we can choose the way we live
If you can't fix it with a hammer, you've got an electrical problem.
I think Congressmen should wear uniforms like NASCAR drivers so we could identify their corporate sponsors
byrd is offline   Reply With Quote
Old 07-14-2005, 05:42 PM   #5
krue
Designated A-hole!
krue's Avatar
I need to write up a FAQ for this with pics, hopefully this weekend.
www.daveramsey.com
Old 07-14-2005, 06:26 PM   #6
shifty
Questionable
shifty's Avatar
if you're going from a 3-hole dash to a vacuum dash, don't forget to rewire everything or you'll fry something
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link)
I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM.
shifty is offline   Reply With Quote
Old 07-14-2005, 08:05 PM   #7
Already Gone
Thanks for the good and quick responses.. I am just changing the bezel, not the gauges .. Should I still loosen the steering column if I'm just changing the bezel ?
Old 07-14-2005, 09:11 PM   #8
byrd
Union Electrician
byrd's Avatar
absolutely it will make it so much easier. You have to take the cluster out of the truck to change the bezel anyway, and that's where the loosening it will come in handy, easier to get old one out and lessen the chance of scratching te new one. Randy
Zip:40272
Old 07-14-2005, 10:01 PM   #9
krue
Designated A-hole!
krue's Avatar
Another tip is to reach up and remove the top row of bulbs, they just turn a 1/4 turn and
they're out.
www.daveramsey.com
Old 07-15-2005, 10:55 AM   #10
Already Gone
Really !!!
You mean if I take the headlite and wiper knob off and the 4 or so outside visible screws holding the bezel on it just wont come of from the front, I have to go under the dash and undo the gauge cluster as well just to get the bezel off.. If that is the case that was sure some dumb engineering by GM back then, and I'll wait till I get my new gauges before installing the bezel.
Old 07-15-2005, 11:03 AM   #11
byrd
Union Electrician
byrd's Avatar
I wouldn't say it was dumb, they had to have room behind the bezel for the headlight switch and the wiper switch so the inner part of the cluster had to be smaller, no choice. there is 8 screws that hold the bezel to the rest of the cluster and the bezel is what hold it all in place with the 6 screws you can see from the outside. to undo the cluster takes all of 3 minutes, remove the knobs as we said earlier, unhook speedo, unplug the cluster, then unscrew the oil pressure line( if appliciable), remove the two screws that hold the u shaped plate to the dash where the column enters the dash to get to the bolt to loosen the column,then loosen the column and then remove the 6 screws that you can see from the outside and it will slip right out. reverse these instuctions exactly for reinstalling the cluster. It's really very easy and only takes about 30 min to get old one out and new one in. Randy
Zip:40272
