Old 07-15-2005, 12:28 AM   #1
benscool1
benscool1's Avatar
Front clip swap?
What all would be involved in changing a 72 gmc front clip to a 68 chevy clip? I know I'd need new fenders and grille. Would I need a chevy hood and radiator support too?
Ben
84 C10 Silverado
14 Silverado Z71
benscool1 is offline   Reply With Quote
Old 07-15-2005, 12:53 AM   #2
1971custom
1971custom's Avatar
you would need fenders and core support could use hood every thing else should fit \if you want to could ya sell the gmc grill
1971custom is offline   Reply With Quote
Old 07-15-2005, 01:30 AM   #3
benscool1
benscool1's Avatar
K thanks, I don't have the truck yet, just getting ideas.
Ben
84 C10 Silverado
14 Silverado Z71
Old 07-15-2005, 05:09 AM   #4
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
actually, the fenders will be the same. However, i would say to get a whole front clip myself...that way trim holes will be correct and you can always sell your GMC stuff to recoup the added expense.
Old 07-15-2005, 05:30 AM   #5
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
Are you just going chevy or do you like the rake of the 67/68 hood? If so you'd need to swap hood. I agree with Andy, swap the whole front clip. Get the "grave guard" across the front of the core support also.
I swapped from a 70 gmc to a 72 chevy was able to use the GMC wiring harness as both trucks had gauges.
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs
1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX
1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears
1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now.....
1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone.
1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed.
1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm
JIMs70GMC is offline   Reply With Quote
Old 07-15-2005, 06:08 AM   #6
dwaite72lnghrn
Should be easy swap of the whole front unless it has air. Then it would get complicated.
72 longhorn c30 502BB/th400/fact air/4.11rear/ custom camper
72 bug(the better half's) under reconstruction
2009 HHR aqua blue
71 GMC k20 350/sm465
2009 Chevy hd3500 6.6 Victory Red crew cab dually
Dave & Jeanne
dwaite72lnghrn is offline   Reply With Quote
Old 07-15-2005, 09:49 AM   #7
dubie
dubie's Avatar
I swapped from a 72 Chevy to a 67 GMC on mine. I used the entire clip, fender (inner and outer) hood, grille rad support and the wiring harness
My name's Tim and I'm a truckaholic
My 56 Chevy shop truck build
http://67-72chevytrucks.com/vboard/s...d.php?t=562795
dubie is offline   Reply With Quote
