temperature guage
What are obvious reasons why temp. gage sits in off position. It it hooked to senor on block with green wire headed towards firewall and into a harness.
Any common things to look for? (all other gauges work)
Bob |
#2 | |||
Union Electrician
Not totally sure what you are asking for, but is it going all the way too hot and staying there? or is it not moving at all? Randy
![]() ![]() Help support the board->HERE Board vendors -> Vendors list Zip:40272 Big Sandy Survivor... Quote:
Not moving at all
Randy;
This one just sits in cold or off position and never moves up when warm. Appears like it isn't even connected. I was wondering if there are common symptoms that might cause this like gauge dying or ? Or other question would be how should I go about trouble shooting it?
Bob |
Msgt USAF Ret
![]() ![]() Join Date: Jan 2005
The sender might be bad. Try grounding the wire from the sender and turn the key on and see if it goes all the way to hot.
VetteVet metallic green 67 stepside 74 corvette convertible 1965 Harley sportster 1995 Harley wide glide Growing old is hell, but it beats the alternative. |
strange missing posts
I just got a notification in my email that said the following post waw made but it doesn't show up on boards for me. This also happened a few days ago.
"Hello cheyenne10, jhow66 has just replied to a thread you have subscribed to entitled - temperature guage - in the The 1967-1972 Chevrolet & GMC Pickups Message Board forum of The 1947 - 1998 Chevrolet & GMC Pickup Message Board Network. This thread is located at: http://67-72chevytrucks.com/vboard/s...1&goto=newpost Here is the message that has just been posted: *************** Check to see if it is plugged in here (tan wire):
Bob |
#6 | |
Sorry that was me--deleted it--had fuel gauge on my mine.
56 Chevy Bel-Air 2dr. HT (purchased new) 71 Chevy Cheyenne SWB PU (502HO) 65 GMC short bed step--work in progress and my gofer |
#7 | |||
Union Electrician
Bob
I went out to my truck and the engine is at operating temp and I was getting 3.8 vdc across the terminals connected to the printed circuit. You could check that to see if you are getting power to the gauge first. I'm not sure if the voltage measurement stays the same with a different engine temp, but the resistor on the back of the gauge should have about .072-.076 ohms of resistance, not sure on the scale so might be off a decimal or two ![]()
#8 | ||||
Union Electrician
