Old 07-15-2005, 09:19 AM   #1
motocrosschump
Removing the Tranny?
I can't even loosen one of the bolts on the tranny to separate it from the engine. I have put penetrating oil on it and its still a b****. there is not enough room to get a cheater bar on it. Any ideas?
2006 Titan SE Crew Cab Daily Driver
2005 Mazda Tribute (Wifes car)
1969 C10 SWB 350/3 Fleet "Max"
1969 Chevelle 2 door 350/3
motocrosschump is offline   Reply With Quote
Old 07-15-2005, 09:39 AM   #2
Gray Ghost
Gray Ghost's Avatar
Use PB Blaster to lubricate the bolts...several coats might be necessary.
Kelly
'05 GMC Sierra SLE Z71
Bone stock except for new bed rail caps.
Gray Ghost is offline   Reply With Quote
Old 07-15-2005, 10:05 AM   #3
VetteVet
Msgt USAF Ret
VetteVet's Avatar
I usually drop the crossmember and lower the tranny and then use a couple of extensions with a breaker bar or my impact tool, be sure the distributer cap clears the firewall and the fan clears the radiator, and be sure to support the engine.
VetteVet
metallic green 67 stepside
74 corvette convertible
1965 Harley sportster
1995 Harley wide glide
Growing old is hell, but it beats the alternative.
VetteVet is offline   Reply With Quote
Old 07-15-2005, 10:20 AM   #4
dubie
dubie's Avatar
i usually yank the tranny while it's attatched to the engine. Much easier to split em on a bench or on the floor
My name's Tim and I'm a truckaholic
My 56 Chevy shop truck build
http://67-72chevytrucks.com/vboard/s...d.php?t=562795
dubie is offline   Reply With Quote
Old 07-15-2005, 10:25 AM   #5
shifty
Questionable
shifty's Avatar
Quick solution that will benefit you for years.
I had the same problem. I went out and bought one of those right-angle impact wrenches and hat to blast mine off. PB wasn't do crap. I bought a new compressor while I was at it. Total cost: $200. I could have borrowed one from a friend, but ... needed my own stuff. Didn't need anything fancy, just something to use in the garage. Someone stole my old one.
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link)
I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM.
shifty is offline   Reply With Quote
