will a suburban radiator fit in my truck
Will the radiator out of a '72 suburban fit right into my '72? The radiator was pulled out of the '72 suburan along with the 350 & tranny that I am putting into my truck. What should the radiator demensions be for a '72 pickup with AC?
Mike
The radiators are the same,suburban-truck-blazer.There are different radiators .
70'c/10, 71 suburban4x4 402bb, 72suburban 4/6 drop, 72k/5 4x4 blazer 4" lift 35 tires |
Some trucks and burbs had 4 core radiators. If your going from a 4 to a 3 core truck or burb, then you have to change the lower radiator mounts as well as the upper mounts. You can get them from some of the venders on the board. If they are the same size ( meaning 2 or 3 core radiato ) they will fit.
Good luck, Matthew
69 swb stepside, rebuild and upgrade in progress |
