Old 07-15-2005, 05:36 PM   #1
Nima
Blue 67
Another general ??
Hi every body:
Can anybody tell me the difference between LB7 and LLy duramx diesel? I know chevy changed to LLY on Jan 2004, but what are the changes as far as performnace and durability goes?
Thanks.
Nima is offline   Reply With Quote
Old 07-16-2005, 01:28 AM   #2
Rooster's 67
Rooster's 67's Avatar
LB7 engines usually will get better milage than the later LLy motor that makes more horsepower and torque,why do you ask,,,, purchasing one?
Rooster's 67 is offline   Reply With Quote
Old 07-16-2005, 05:22 PM   #3
68C15
blood type; Retumbo
68C15's Avatar
did they move the injectors so you only scrape 8 knuckles replacing them? different injectors that cost more than $500 each?
Man rule #77...if you own a 67 stepside with a caddy 472 you will never be in danger of loosing you man card
Last edited by 68C15; 07-16-2005 at 05:24 PM. Reason: yard work is not easy, but well worth it in the end.
68C15 is offline   Reply With Quote
