Air tank question?
Should i run a gauge for my air tank or get a pressure switch? i was planning on running the compressor just to raise the bags, but i don't want to over pressurize the tank. any advice??
2014 GMC Yukon XL (Wifey's) 2004 Chevy Silverado Crew Cab Z71 |
i dont think you would have a problem with a compressor over pressurizing it but my buddy just did a bag set up on his supercrew and he got a adjustable pressure switch from suicidedoors, seemed like a pretty nice piece i would recomend it over any other ones i have seen used....
49 Chevy - currently under construction being bagged and hunting for a LS drivetrain!!! 09 - Harley nighttrain on air ride! |
sorry too jump in, but my pressure s/w stopped workin awhile back. I thought about getting a new one, but for now i have installed a manual s/w in the cab to control the compressor. I like this better cuz if i am cruising down a crowded downtown street, i don't want to listen too my loud compressor, plus its annoying at night sometimes (ie: residential areas) so now i can run it when ever i want, or need. I have a gauge mounted in my truck so i know when i am full. Maybe when i get a new pressure s/w i'll hook it in series so so can do the same, but then i know it will never over fill. Just wondering if anyone has any thoughts on this?
If you can't rock the roads with your bumpers 1/2" off the ground, you're nowhere near low enough! ![]() |
Just drag it
I had a presure switch for a while (they don't work well in rain). It was cool, did what it was suppost to. Then I took it off because I wanted to run 200PSI, so I just hooked up a gauge from the tank (easy). Then I want to run nitrogen 250-300 PSI. They all work just depends how you wanna do it, but if your running a compressor it will blow up before you over preasure that tank, My friends are dumb enough to run their compressors at 200-215 with 12 gallon tanks not a
#5 | |
hmmmm, i don't drive my truck in the rain, but seeing as it is mounted open in the box of my truck, maybe it stopped working from washing it? Just outta curiousity, how much does it cost to add nitrogen? and do you need it too hop? i only have 3/8's" line right now and want it way faster, not really looking TO hop, but that would be kewl. Right now my valves are mounted in my box. I am planning on changing to 1/2" lines an relocate my valves as close as possible to the bags. Also is there a special bag you need too install for hoppin or really fast setups?
#6 | |
Just drag it
Good Regulartor-$100
Bottle Bracket Made From 4 piece of angel iron-$5 BILLET NITROGEN BRACKET-$400 Bottle-$10 bucks to change out Rent-30 bux a year here I'm gonna go with Yes you need it to hop, unless your have a york compressor like I do now. With bags I would go with slams, cause they have an awsesome warrenty program and your gonna blow one or two up hoppin it. |
