07-16-2005, 12:29 PM | #1 |
Lowering truck
My son wants to lower his 72 GMC longbed. If we use 2.5" spindles and 2" drop springs will this be too low for a daily driver. Also he is 17 years old.... When you lower the front that much do you need to change shocks? Forgot to add he will be running 15x8 rally wheels with 255 / 60 tires.
Thanks, Parrish Last edited by PMS; 07-16-2005 at 12:30 PM. |
07-16-2005, 01:13 PM | #2 |
67 is sold
By running lower coils, you'll need different shocks. a 4" drop is fine for a Daily Driver, he'll just have to be more careful at the bottom of some driveways, speed bumps, etc.
What are you going to use to drop the rear? Is it leaf spring or coil spring? |
07-16-2005, 03:44 PM | #3 |
It is a leaf spring rear. I was going to contact a local spring company to handle the rear after we got the front done.
07-16-2005, 04:29 PM | #4 | |
67 is sold
www.gmcpauls.com www.mothertruckers.net |
07-16-2005, 09:43 PM | #5 |
and lowered all the way around looks soo much better...
07-16-2005, 11:02 PM | #6 |
blood type; Retumbo
Lefty has about a 5" front & 7" rear drop. I run 3/4 ton shocks with no problem.
not to mention I have the same front tires with 275/60 's on the back. clearance is sufficient
Man rule #77...if you own a 67 stepside with a caddy 472 you will never be in danger of loosing you man card |
