Old 07-16-2005, 01:58 PM   #1
motocrosschump
ok last questions for a bit (maybe)
I got the I6 out and noticed the flywheel looks completely different than on the 350. The 350 is out of a 95 and had a automatic tranny. I want to mate it to the 3 speed in my truck.
Do I need a new flywheel out or can I make it work with one of the two flywheels.
2006 Titan SE Crew Cab Daily Driver
2005 Mazda Tribute (Wifes car)
1969 C10 SWB 350/3 Fleet "Max"
1969 Chevelle 2 door 350/3
motocrosschump is offline   Reply With Quote
Old 07-16-2005, 02:11 PM   #2
fastwillie 696969
~Rest In Peace~
fastwillie 696969's Avatar
automatic use a flex plate and clutch uses a flywheel so you need a flywheel you can get a 168 teeth flywheel for 150 or so
check this place out www.enginekits.com for a flywheel
is it fast ? it has a lighting bolt donut?
B___H please, I can remove 90% of your so called "beauty" with a kleenex
fastwillie 696969 is offline   Reply With Quote
Old 07-16-2005, 02:21 PM   #3
Josh
He's got mean nasty FANGS!
Josh's Avatar
You need a one piece rear main flywhee for your late model block. An 88-95 5spd flywheel from a truck should work.
2004 K2500 Burb
1999 C3500
1985 Cutlass Supreme
1969 C-10
1967 C-10 Panel
josh@67-72chevytrucks.com
Josh is offline   Reply With Quote
