Tommorow it's door hinge rebuild day.
I've been plugging along and doing something on this truck every day. I received my door hinge rebuilding kits (and catalog) from Chevy Duty on Friday. I really like them as they seem much better than the original with the bronze bushings. The hinge rebuild looks pretty straight forward and I don't plan to take the forward half of the hinge off the cab. It looks like I'll take a cut off wheel and cut off the bottom of the existing pins then drive them up and out. The new bushings get installed and pins get driven back in.
I'm sure some of you guys have done this before so wonder if there are any pitfalls or tricks for this job? |
Enormous Member
Ya I am ready to do the same and would like to hear the short cutz....
"79" Chevy Stepside 350/350 Check my Blog @ www.BaldMikesWorld.blogspot.com |
If a round bushing is place in a out of round hole it too will become out of round. Drill proper size hole through bushing to correct problem.
1978 c10 stepside 4/6 drop 350 vortec crate 2011 camaro ss2 6.2 automatic 2017 tahoe lt 2002 silverado lt 1500 5.3 automatic. 1981 el camino |
I plan on doing my doors soon too.. they are getting pretty bad.. I have to lift the door in order to turn the key..
needin' money
me and my friend put the new ones on the truck a couple weeks ago, but i didn't have a drill so we need to take the door back off, and put the other bushing in it
SWB Stands for Short Wide Bed |
make sure to take some pics.. and postem up
I have several parts trucks around so have plenty of hinge "cores". I took a set of hinges off the 77 cab I have and found the upper was broken and thought the lower was actually in good shape as the nylon bushings were intact. Dissassembled it by slightly grinding off the piened enlarged portion on the bottom of the pin with a Dremil then driving it out. Found the pin was bent.
Removed the door from the 79 truck the rebuilt hinges will have to go on. This lower hinge has a broken strap while the upper has worn out bushings, a worn out tension wheel and missing tension spring.
I guess I'm going to remove some hinges from some of my parts trucks and pick the best parts to rebuild with the new bushings and pins. Meanwhile I'm cussing at those damn GM designers as these hinges sure could have been better engineered in the first place. |
Drivers side lower hinge rebuilt. I did have to slightly ream the cab side of the hinge to accept the new bronze bushings but everything else was straight forward. The bushings go in with the collars to the outside. With the smallest dab of lithium grease it works as smooth as glass now.
