bad wheel hop driving my lwb 70 K-10
What are some cures for my bad wheel hop? I've had this truck for years and when the hot 355 went in the problems started. with the 3.07 open rear end I would one wheel hop down the street. I then installed a locker with 4.10 gears. The problem compounded to two wheel hop. Shaking the whole rear end pretty vioently.
I can try not to abuse my rig and lay off the skinny pedal. But its fun lighting it up. I know my rig isn't built like a drag car. But some ladder bars or something would help. I don't want to comprimise clearence as i drive on trails. what do you think? thanks
70 K-10 75 CJ-5 90 XJ Smell the Magic! |
I have added leaf spring u-bolts to limmit axle wrap in the past, also make sure your shocks and bushings are in good working order. Wheel hop has ruined alot of drive train parts in my truck so be carefull. My wheel hop problems are cured now that I invested in new skyjacker leafsprings. Good luck
1971 GMC K1500 SWB Fleetside, 4" skyjacker softride and, 14 Bolt FF, HD Dana 44 4.10's 1970 K5 TBI conversion lifted etc SOLD 1968 C20 camper truck SOLD “To ban guns because criminals use them is to tell the innocent and law-abiding that their rights and liberties depend not on their own conduct, but on the conduct of the guilty and the lawless.” Jeff Snyder |
user # 2756
![]() Join Date: Jun 2001
Do you have blocks in the rear? sounds like you need traction bars to limit axle rotation and not effect articulation.
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs 1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX 1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears 1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now..... 1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone. 1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed. 1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm ![]() |
I don't have the rear end lifted with blocks. Just stock hieght. Last year I put brand new Pro-Comp es3000 shocks on. No help. I'm looking at tracktion bars but they hang way to low. What about this?
out of four wheeler mag- this is on a 1970 badass blazer. Rear grunt comes from a swapped GM corporate 14-bolt axle with a Detroit Locker and 4.56 gears. Custom ladder bars were installed to prevent wheelhop and axlewrap.
70 K-10 75 CJ-5 90 XJ Smell the Magic! Last edited by Dr.Jones; 07-18-2005 at 08:33 PM. |
#5 | |
The Blazer King
72 2wd Blazer. Its the superbichinest, megacoolinest, superflowinest. |
user # 2756
that rear is definetly not a 14Bff, looks like my corporate axle, pre-14BFF. I've seen several companys that make traction bars that extend up from the top of the axle tube and attach to a new crossmember that extends from the top of the frame, therefore nothing extends down, one had a shackle at the frame end.
Blackbirds trucks do traction bars. Look up member drink2mny he can help ya.
