07-18-2005, 05:59 PM | #1 |
Jammed Ignition Switch
Last night I had the key turned backwards listening to the stereo. When I was done, I turned the key forward to start it and move the Burb. The switch jammed after I moved it forward. The switch is in the off position. It will not move at all. To start it, I moved the HEI power wire to a constant hot lead on the fuse panel and jumped the starter. Is the battery still getting charged this way?? And does anybody know how to "unjam" the switch??
07-18-2005, 06:16 PM | #2 |
Id try to wiggle it with a little WD40 first. It might have came part way out when it was turned to the left (to get it out you turn it left with a paperclip in the hole)
1971 Chevy C10 Shortbed Stepside, 307v8 3-on-the-tree |
07-18-2005, 09:37 PM | #3 |
theres a little blackdot on the switch jam a allen wrench in there and try turning teh key back and foruth that releaces the cylinder and you can go from ther
07-19-2005, 10:14 AM | #4 |
Well I got it "unjammed". It wasn't hard to do. I just didn't have time to mess with it in the morning before work. A little tap with a small hammer seemed to work. Thanks for the replies. Which vendor sold the key sets for Burbs (3 doors + panel doors)???
