Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > The 1973-1987 Chevrolet & GMC Pickups Parts Board
Old 07-18-2005, 07:22 PM   #1
corn
Who has a cheap
upper radiator support & both lower rubbers? Im too lazy to go to the junkyard & take them off. I seem to have lost mine. How can a guy lose a big piece of metal like that? GEEEEZ...corn
corn is offline   Reply With Quote
Old 07-18-2005, 08:28 PM   #2
full foot notch
hey cornfed, ive got the upper support panel for a 350 rad
what about the driveshaft, never heard back from ya
full foot notch is offline   Reply With Quote
Old 07-18-2005, 09:31 PM   #3
corn
Are the panels all the same? My radiator is from my '84 w/305. I still want the driveshaft but I dont have quite that much cash right now. If you still have it when I get paid again Ill probably get it from you then...corn
Old 07-18-2005, 10:33 PM   #4
full foot notch
lookin at the chevy duty catalog, yours is the 81-87 "radiator upper cover panel, IE what locks the top part of the radiator
only 14.95 according to the catalog i have
78-845 for the two bolt tabs on each side
78-846 for the one with the single bolt hole coming out of each side
ill have the driveshaft for a while, so its still yours
Old 07-20-2005, 08:07 PM   #5
ozrulzk5
What can I do next ????
Rad
Hey corn I thought the rad was held into place by two small brackes and rubber that bolt to the rad support. I have an 85 k5 and I think they are the same back to 81. now my 74 454 had the large plate that went all the way across the radiator and you could not see the top. but on the later ones the fan shroud is off set to cover everything up and it bolts to the two small brackets that hold the rad. so maybe you are not crazy and just overlooking the brackets. probably the ones in front of the tire to keep if from rolling away (done that before and went insane looking)
ozrulzk5 is offline   Reply With Quote
Old 07-20-2005, 08:27 PM   #6
corn
Hmmm, its been so long sinse I tore it apart that I cant remember. You may be right. Ill keep digging. Thanks...corn
