Old 07-18-2005, 09:18 PM   #1
hamrhed
Unhappy found out what that noise was
i posted a few days ago that i had a clanking noise coming from my rear end,and after careful inspection fund some missing tranny/bellhousing bolts and replaced the missing hardware. well that wasent it. I drove to work this morning and herd the noise again and thaught what the hell is it now??? at work i talked dto a few friends that dident have a clue eather one stating that ill find out soon enough when it breaks and jokingly i concured and set yea then i can fix it. got cut lose around 0730 because weare leaving country soon, and sure as hell at the speed bump rite before the back gate the right rear tire shot off and down i went . i skidded off the road stopping 5 feet from the tank track breakers ( they use them t stop terrorists from charging the fence cause they will total a vehicle) and i watched my tire roll by and hit the gaurd shak. some poor bastard was in there most likely reading a 6 month old off stuff and then wam! he thaught the gaurd shack was being attacked and damnear shot me coming around the corner. the problem was the studs hey broke and will the rest is history really biffed my bed up but after all the dents i pulled i recon it really dosent matter any how ill fix it too well that was my day how was yours ill post pics soon
hamrhed is offline   Reply With Quote
Old 07-18-2005, 10:05 PM   #2
Green Machine
Green Machine's Avatar
Not trying to hijack here, but I almost posted this a while back. The answer may be easy, but do you think wheel 35 year old wheels studs should or need be replaced as a maintenance item, or if they look good just leave them alone ? Are generic parts store studs OK, or is something like an ARP needed ? I have the 6 bolt with the 7/16 studs, thanks.
1968 C10 307 3spd Long Fleet ------ http://67-72chevytrucks.com/vboard/s...d.php?t=201103
1970 C10 305 Super T10 Long Fleet --- http://67-72chevytrucks.com/vboard/s...d.php?t=202285
1971 C20 383 TH350 Dana Posi ----- http://67-72chevytrucks.com/vboard/s...d.php?t=206894
2001 GMC Sierra 1500 C3 6.0
Green Machine is offline   Reply With Quote
Old 07-18-2005, 10:30 PM   #3
saulgoode
saulgoode's Avatar
I feel your pain, been there done that. Lost a bfg 33x12.50 at close to freeway speeds. Glad to hear you made it out safe.
@Green Machine: If it were me I'd replace them, small price for piece of mind.
Saulgoode
saulgoode is offline   Reply With Quote
Old 07-18-2005, 11:10 PM   #4
hamrhed
i think the reason for failuer was more my part but after 35 years a few bucks to change them would be a good idea cheap insurance
Old 07-18-2005, 11:13 PM   #5
Green Machine
Man, just remembered , I better change those, about 20 years ago made a 10 mile drive at 120 mph with 3 buddies to the next tavern in my 68 chevelle. Pulled off on a gravel road to drain some used beer, going about 40 then, about 1/2 mile down the road the right rear tire, big meats, squirted out from under the car, tire went way out into the field, we landed on traction bar and stopped, bent fender, but if that would have come off when..................???????????
Old 07-18-2005, 11:37 PM   #6
tomatocity
tomatocity's Avatar
Lucky man Charlie Brown that you and others are safe and healthy. Did the guard take a latrine break following the incident or was that a laundry break
Got bored, sold everthing. Got bored, looking for a 1960-66 C-10. Want to build my last truck.
tomatocity is offline   Reply With Quote
Old 07-19-2005, 12:18 AM   #7
krue
Designated A-hole!
krue's Avatar
Been there done that with a 67 elky I had. Damn one size fits all rims suck!
Being stupid ain't illegal.
www.daveramsey.com
93 S-10 "Poppaw's Truck"
Old 07-19-2005, 10:50 AM   #8
ckhd
ckhd's Avatar
Certain rims will break studs. My '69 has cheap "wagon wheel" rims, and those are stud-bustin' mothers!
my 2¢ - t.i.o.l.i.
Bowen
1968 K20 fleet
1969 K10 swb fleet
1972 K10 Suburban
1972 C10 lwb step
1992 K1500 'burb
1995 K2500 'burb
1997 C1500 'burb
1999 K1500
2000 K1500 'burb
Why do I own so many Suburbans?
ckhd is offline   Reply With Quote
Old 07-19-2005, 10:37 PM   #9
chevymad
When I had aluminum slots on my 70, it ate several sets of studs. One day my brother was driving and both rear wheels come off. Ended up taking dad's backhoe lifting the rear up and wheel barrowin the truck home to be fixed. Even with the centerline hellcat's I had one front one try to come off on the freeway. Things started vibrating terribly. Ended up not being the studs themselves but the front drum hub. All the studs started working loose in the hub. After switching to front discs and finding some longer and slightly larger in diameter rear studs things have been real good.
chevymad is offline   Reply With Quote
Old 07-19-2005, 10:42 PM   #10
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
The turbines I had (and the wagon wheel spare) liked bustin lugs on the old 69 GMC.
'Had an '80 chevy Monza that tossed a wheel once. I was only doin 40, but that's enough to make you panic.
Like Bill Cosby said....
First you say it...
THEN you do it!
(sh!t)
Old 07-19-2005, 10:58 PM   #11
68C15
blood type; Retumbo
68C15's Avatar
torque wrench
Man rule #77...if you own a 67 stepside with a caddy 472 you will never be in danger of loosing you man card
68C15 is offline   Reply With Quote
Old 07-20-2005, 12:55 AM   #12
sdkid
Originally Posted by 68C15
torque wrench
I agree, but not just once. Especially with alloy wheels, I am a firm believer in retorqueing ever oil change or so.
I think the world needs a drink...
Help somebody...If you can....VanZant
We're not wrong, we're not sorry, and its probably gonna happen again. That's the truth about men.
Tracy Byrd
Member# 13924
'70 c10, 350/350
'68 c10 250/4spd
'68 c10 no eng/trans fac ps/pb/ac/at
(future father/sons project)
'48 Chevy Loadmaster
sdkid is offline   Reply With Quote
