Stock 72 tach
Will a stock 72 tach work with a HEI dist.
56 Chevy Bel-Air 2dr. HT (purchased new) 71 Chevy Cheyenne SWB PU (502HO) 65 GMC short bed step--work in progress and my gofer |
Strongman Garage
![]() Join Date: Apr 2000
yes, mine does
Kalle 68 GMC Suburban 1500 4x4 SOLD 69 Pontiac Lemans 99 Silverado 4.8 5 speed ECSB [ Facebook Instagram Subscribe on YOUTUBE |
tach
Thanks for the reply.
www.geocities.com/jhow66/2-.html
YES BUT---the stock tach is made for traditional ignition and HEI puts out more so that the tach will read significantly higher rpm then actual. So as long as you are happy with the tach moving, it's fine but don't rely on the actual numbers being real. Look into the ColoradoK5 board (believe it was Steve Chein) for details of how to modify for accuracy.
Location: Help! I'm in an office park with its own network of freeways!
Now, unless I miss my guess, the stock tach counts revs the same way aftermarket ones do: off the coil ground. Coil output has absolutely nothing to do with counting revs. The repeated cycling of power is what triggers an electric tach.
'67 C20--427 tall deck/SM420, 4.10 HO52 (Michigan has not been kind to the Old Man) '95 Caprice--355 LT1/T56/3.42 8.5" 10-bolt (daily driver, almost 300k on the chassis) '07 Outback--wife's car. 125k & counting. No head gasket or transmission issues yet. *fingers crossed* |
![]() Join Date: Dec 1999
There is a hole in the back of the tach for adjusting it. It takes a phillips screwdriver. The hole is usually covered by a sticker.
72 Shortbed fleetside 402 BB, AC, Posi 72 Super Cheyenne Longbed 350 49,000 original miles and My dad ordered it new 66 Chevy Caprice 2 dr 74 Honda CB750 New Palestine, IN |
![]() Join Date: Mar 2000
Mine works fine.
Saskatoon, Saskatchewan Canada |
Not my good side.
Mine works too, but I suspect it reads a bit on the high side.
72 Chevy K20 Custom Camper, 350/350, 4" lift, dual shock suspension front & rear. Daily driver and a work in progress. 00 Suburban LT 90 Camaro RS 79 Yamaha XS1100 Special (Ol' Reliable) |
faster, faster, faster
It works on how fast the rotor makes it from #1 contact to #8 contact, not how many volts are put out. If it reads higher it is because of interference because of a frayed wire in the harness or something of that nature, not the HEI distributor.
I'm going to Law School, wanna debate? It's good practice. |
Tach
Thanks guys for all the replies. One of my friends changed from points to HEI--tach worked before change. Will check out his wiring tomorrow.
