![]() Join Date: Dec 1999
Pulleys and Brackets
I have several crates of pulleys and brackets, most are small block but I have a few big block pulleys lurking around. All are for short water pump.
67-72 AC Brackets complete set $60 Alternator brackets complete set is from a '64 Chevelle $20, lower cast iron is 69-72 PU $10 Stamped steel pulleys 2 row w/ AC $15, 2 row w/ac hiperf deeproove $35, 1 row non AC $6, PS add-on $15, big block 2 row $25 power steering brackets are from a 68 Impala $25 cast iron pulleys- i do not remember what most are off. most are 2 row 1-3 row a couple are deepgroove $5, i have 2 1 row big block 69 only AC dealer add on (long pump) $10 ea, 2-69-72 2 row cast $15 ea I also have numerous water pump 1 and 2 row pulleys. $10-$25 each shipping is via flat rate priority usps. shipping is $8.00 regardless of weight includes tracking number. |
computer illiterate
i would like to have a full set of swp bbc brackets and ps pump
72 2wd blazer 72 swb 4x4 |
meathead. sorry all those sets i use to have are long gone. All i have is a couple crank pulleys, water pump pulleys, I also have 5 of the 7 bb AC brackets. I wish i had some of that stuff still. I'm sure i'll need it when i find another truck. I may just go with the cheap long pump stuff?
#4 | |
The LuvShack Garage
WOW, now that's a deal, top right bracket alone is worth that 2 some people ![]()
Owner/Op: "TN Classic Transport Carriers" The Toy: "Square Vette" 72 Hybrid Blazer Toy Barn: "LuvShack" 40 x 60 x 20 Shop Tow Piggy:"Maddy" 88 Silverado 3500 Hauler: "Feathers" 14 Aluma 8218T |
![]() Join Date: Jan 2005
PM sent regarding 67-72 AC Brackets complete set
68 Short Stepside C-10 69 SWB C-10 70 Flatbed C-20 70 LWB C-20 BB402 70 LWB C-10 CST 70 LWB C-10 CST 71 Short Stepside Cheyenne C-10 72 LWB C-10 72 Blazer 4x4 4spd 95 Jeep Cherokee 4x4 |
Yeah I use to get $40 for that one alone. Checking PMs
SB A/C Brackets have been spoken for. Thank you !
55454
sent e-mail on bb a/c
Thanks Tommy |
Tommy- You have first dibs if you are interested.
http://67-72chevytrucks.com/vboard/s....php3?t=164902 |
55454
Micah,
I got the brackets today, they were nicer than you explained, that was quick. Thanks Tommy
72 Cheyenne 1956 3100 1955 210 19 year old Chihuahua (Factory Teeth) |
Thanks Tommy! Pleasure doing buisness. I'm going to try my best and shipping within the next day or two of recieving payments. Thank you!
BOWTIE FOREVER
Hey Desert Rat glad you still around bud.
69 C-10 SHORT FLEET BED 350 4-BOLT/400 turbo upper & lower molding 65 IMPALA 2-DR 283/POWERGLIDE 66 IMPALA 2-DR hopefully 283/350 ~ CAMELTOE ROCKS ~ |
#13 |
Which of the 5 bbc ac brackets do you have?
SEMA Network- Protect our Hobby! 71 C30 in pieces, starting to come together. Click here for A Place For Tennessee Truck Enthusiest To Meet |
#14 | |
67 is sold
Thanks. |
#15 |
Hi- Heavy Chevy!!! Glad to be back.
woodridge-sorry the big block ac brackets are sold. 67 step. I have several small block short pump ac wp pulleys. There are a few different styles. Is there a certain one you want, or just want it to work? let me know. Shoot me a PM |
#16 |
![]() Join Date: Aug 2004
Any 2 groove BB (short) water pump pulleys? Mine's beat up.
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO http://67-72chevytrucks.com/vboard/s...d.php?t=788602 93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday... 05 Jeep Wrangler Unlimited. 3” lift & 6-speed 02 E320 the insurance total “free car” 13 Tahoe LTZ |
#17 |
New
Do you have a 4 groove lower pulley? I need one for my 1970K20.
Thanks |
#18 |
Clay. I have a lower 2 row crank pulley and water pump pulleys. Crank Pulley $35 shipped
Gramps. I have never seen a 4 groove pulley, I do have 2 row inner for and the outter 2 row cast pulley. $35 shipped for both. |
#19 | |
67 is sold
I just want one that will work properly. Thanks. Joe |
#20 |
Check your PMs.
This is a picture of what I got now.
'70 cab, '71 chassis, 383, TH350, NP205. '71 Malibu convertible '72 Malibu hard top Center City, MN |
#21 |
55454
Micah, that four groove pullie threw me for a loop also, it must be a 1970 thing and it is original. I think this set up was made to keep the p/s in the fourth position and discontinue the use of the cast pullie. So instead of skipping the second groove they put a non-used groove, I guess the metal was not as sturdy as the cast.
They cast three grove should be the same their is no second position but it is not needed. The belts fall as follows: First groove is 1/2" from balancer (ALT) Third groove is 1 11/16" from balancer (A/C) Fourth groove is 2 3/16" from spacer (P/S) It has the same pattern as a 1967 with power assit. Thanks Tommy
#22 |
Tommy. Its hard to say. I have a small pile of 3 and 4 groove cast iron pulleys, they look like they are for small block but i am not 100% sure. Most of my stuff is from these trucks, but some might be 6cyl. You never know what GM may have done.
67 step. I believe all 2 row water pump pulleys were for AC or A.I.R. I have a few different styles and small and large diameters. Pulleys I have Basically what I have is 1 row inner crank pulleys (that run alternator no AC) crank pulleys 2 row alternator and AC (3 different diameters) I have a few power steering pulleys left. 3 different depths for the different ps pumps, many water pump pulleys, 1 row and 2 row for AC or a.i.r. few different styles and small and large diameter, I have 1 sbc deep groove crank pulley w/AC left, 1 bbc 2 row crank pulleys, several cast iron 2 and 3 row crank (unknown application) some look like small block. some have large center hole and fit in big block balancer. I have chevy truck 2 row cast iron left (for ac and ps) |
#23 |
New
PM sent
Thanks |
#24 | |
67 is sold
If anyone can help. My 1968 327 will have just an alternator and power steering (that runs off the crank pully I believe) |
#25 |
I have 1 row water pump pulley, and 1 row inner crank and the power steering pulley. I just need to know which ps pulley you need, there are 3 different ones for 3 different ps pumps. Water pump Pulley $5, 1 row inner crank pulley $5, ps pulley $10, $25 shipped for all 3
